跳转到主内容
加入维修社区 - 创建账户
Microsoft Zune 80 Case Replacement
你所需要的
  1. Microsoft Zune 80 Case Replacement, Case: 步骤 1 中的图像 1,1
    • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
  2. Microsoft Zune 80 Case Replacement: 步骤 2 中的图像 1,1
    • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
    • Be careful with removing these screws! These screwheads are prone to breaking.
  3. Microsoft Zune 80 Case Replacement, Remove the Casing: 步骤 3 中的图像 1,2 Microsoft Zune 80 Case Replacement, Remove the Casing: 步骤 3 中的图像 2,2
    • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
    • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
结论
另外一个人完成了本指南。
turey
于11/11/09注册
417 声望
创作了2篇指南
团队
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G5
5 名成员
创作了8篇指南
1指南评论
I have followed these steps but im unable to get the back case off, any tips for a stubborn backing?
zippy9765 - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 76
总计 5,271
