跳转到主内容
  1. 这个步骤还没有翻译 帮忙翻译一下
    Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side. Be gentle when removing the screw cover as it is brittle and will break if forced.
    • Remove the plastic screw cover located on the bottom of the device. Insert a small flat-headed screwdriver into one side of the cover and gently ease it out. Repeat on the other side.
    • Be gentle when removing the screw cover as it is brittle and will break if forced.
    • You will need a #00 Phillips screwdriver to remove the two 2.6 mm screws that are exposed.
  2. 这个步骤还没有翻译 帮忙翻译一下
    Use the blue plastic opening tool to slowly work your way around the edges of the case, releasing the front plate from the bottom case.
    • Use the blue plastic opening tool to slowly work your way around the edges of the case, releasing the front plate from the bottom case.
    • Be gentle when prying the device open.
  3. 这个步骤还没有翻译 帮忙翻译一下
    Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable. The battery is not fastened to the inside of the case. It will fall out.
    • Turn the Zune over so the screen faces downward. This will ensure the battery does not fall out and pull on the cable.
    • The battery is not fastened to the inside of the case. It will fall out.
    • Pry up from the bottom of the Zune because the headphone jack will not allow you to remove the back case in one pull. You must slide the case up and away from the rest of the Zune.
    • The case is now separated. You can replace the case, if needed.
终点
5等其他人完成本指南。
jmorri04
于2009年10月16日注册
200 信誉积分
创作了2篇指南
团队
Cal Poly, Team 19-4, Maness Fall 2009 Cal Poly, Team 19-4, Maness Fall 2009 的会员
CPSU-MANESS-F09S19G4
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 8
总计 6,134
