跳转到主内容
Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement
你所需要的
  1. Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement, Turn the mouse onto its back: 步骤 1 中的图像 1,2 Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement, Turn the mouse onto its back: 步骤 1 中的图像 2,2
    • You will want to use a clean surface to avoid damaging your mouse
  2. Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement, Remove the rear door: 步骤 2 中的图像 1,1
    • Gently press the tab, and pull the door up and away from the body of the mouse
  3. Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement, Remove the battery: 步骤 3 中的图像 1,2 Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement, Remove the battery: 步骤 3 中的图像 2,2
    • Using your fingernail, pull up on the top of the battery and take it out of the slot.
  4. Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement, Add a new battery: 步骤 4 中的图像 1,1
    • Slide the battery into the slot, and push down on it firmly. It will click into place.
  5. Microsoft Wireless Mobile Mouse 1850 Battery Replacement Replacement, Replace the rear door: 步骤 5 中的图像 1,1
    • Slide the rear door back into place, and push down on it. It will click into place.
结论
Done!
Jed Calvert
于02/03/20注册
293 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 42
总计 1,590
