跳转到主内容
Microsoft Surface Pro X SSD and SIM Card Door Removal
你所需要的
  1. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: 步骤 1 中的图像 1,2 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the kickstand: 步骤 1 中的图像 2,2
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
  2. Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: 步骤 2 中的图像 1,2 Microsoft Surface Pro X SSD and SIM Card Door Removal, Open the SSD and SIM card door: 步骤 2 中的图像 2,2
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X SSD and SIM Card Door Removal, Remove the SSD and SIM card door: 步骤 3 中的图像 1,1
结论
另外一个人完成了本指南。
Adam O'Camb
于04/11/15注册
199,413 声望
创作了416篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 23
过去 30 天: 128
总计 9,811
