跳转到主内容
Microsoft Surface Pro X SSD Replacement
你所需要的
  1. Microsoft Surface Pro X SSD Replacement, Open the kickstand: 步骤 1 中的图像 1,2 Microsoft Surface Pro X SSD Replacement, Open the kickstand: 步骤 1 中的图像 2,2
    • Make sure your Surface Pro X is turned off, and laying screen-side down on a soft surface.
    • After turning off your device, make sure to remove the SSD from the Surface before starting any repairs. This will disconnect the battery and prevent damage to the device.
    • Lift the kickstand to at least a 90° angle, so that it is perpendicular to the Surface's screen. The further you open the hinge, the easier it is to access the SSD and SIM card door.
    Where can one find these drives to replace the one that comes with it?
    daveniezby - 回复
    I think I found mine on Amazon
    Tom Manson - 回复
  2. Microsoft Surface Pro X SSD Replacement, Open the SSD and SIM card door: 步骤 2 中的图像 1,2 Microsoft Surface Pro X SSD Replacement, Open the SSD and SIM card door: 步骤 2 中的图像 2,2
    • Insert a SIM card eject tool or a paperclip into the small hole in the bottom right corner of the SSD and SIM card door, located near the bottom right corner of the Surface.
    • Press firmly to open the door.
  3. Microsoft Surface Pro X SSD Replacement, Remove the SSD and SIM card door: 步骤 3 中的图像 1,1
  4. Microsoft Surface Pro X SSD Replacement, Remove the SSD screw: 步骤 4 中的图像 1,1
    • Use a T3 Torx screwdriver to remove the 2.4 mm screw securing the SSD.
  5. Microsoft Surface Pro X SSD Replacement, Remove the SSD: 步骤 5 中的图像 1,3 Microsoft Surface Pro X SSD Replacement, Remove the SSD: 步骤 5 中的图像 2,3 Microsoft Surface Pro X SSD Replacement, Remove the SSD: 步骤 5 中的图像 3,3
    • Use your finger or a spudger to lift the SSD just enough that it clears the edges of its recess.
    • Don't lift the SSD more than you have to—doing so may damage the SSD or its socket.
    • Gently pull the SSD straight out of its socket.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
结论
8等其他人完成本指南。
Adam O'Camb
于04/11/15注册
196,116 声望
创作了416篇指南
6条评论
The only question remaining is: where does one purchase a M2. 2230 SSD?
richard.brock57 - 回复
How do you clone or copy windows to the new drive?
Ismail Akudi - 回复
To “richard.brock57”, you can search for M.2 2230 SSD and you should find retailers including CDW, Newegg and Insight who sell these. Or you can look specifically for a version, such as KIOXIA BG4 (Kioxia is the rebranding of Toshiba’s SSD drive business). Unfortunately retailers do not yet sell the 1TB version (at least as of my writing this on May 12, 2020), so if you really want 1TB you can do what this fellow did:
https://dancharblog.wordpress.com/2020/0... who purchases the Caldigit Tuf Nano 1TB external drive and swaps the Kioxia BG4 1TB M.2 2230 SSD in there for the one in his Surface Pro X. Currently that drives sells for $219 on Amazon.
To “Ismail Akudi”, you can go to https://support.microsoft.com/en-us/surf... to download a recovery image of Windows 10 onto a USB drive and use that to set up your Surface after you’ve upgraded the drive. You can look at the instructions at the link; they’re reasonably straightforward.
Edward - 回复
Where can one find a replacement 2.4mm screw, and what is the exact size/type?
anonymous 8834 - 回复
Even without that screw, the lid will keep the drive in its position. I know :)
BTW: if you still have the screw, don't throw it away. If the screw does not grab the thread, it usually is the thread that got damaged.
Weljo - 回复
What is the specification of the t3 torx nvme screw size? I need the replacement and I cant find it anywhere online
Muhammad Adam Zhuhri - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 97
过去 30 天: 437
总计 32,405
