跳转到主内容
简介
*In order to access the charging port, refer to steps 1 - 6 in the Microsoft Surface Pro Teardown Guide to remove the screen.
Teardown Guide
  1. Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro. Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
    • Using a T5 Torx screwdriver, unscrew a total number of 23 screws located on the outside panel of the Surface Pro.
  2. Use the plastic opening tool or fingers to pry out the front camera.
    • Use the plastic opening tool or fingers to pry out the front camera.
  3. Lift the outside panel from the Surface Pro
    • Lift the outside panel from the Surface Pro
  4. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  5. Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
    • Use the T5 torx screw driver to unscrew the 6 T5 screws in the left and right outside metal panels
    • Use the T2 torx screw driver to unscrew the 23 T2 screws on the left and right outside metal panels
  6. Pull out left and right metal panels with hands
    • Pull out left and right metal panels with hands
  7. Pull out the orange charging port strip using tweezers
    • Pull out the orange charging port strip using tweezers
  8. Unscrew the two T5 torx screws located on each side of the charging port.
    • Unscrew the two T5 torx screws located on each side of the charging port.
  9. Once you have unscrewed the charging port, you can gently pull it out with your hands.
    • Once you have unscrewed the charging port, you can gently pull it out with your hands.
结论
Jonathan Choi
于2013年10月09日注册
600 信誉积分
创作了4篇指南
团队
Cal Poly, Team 8-20, Regan Fall 2013 Cal Poly, Team 8-20, Regan Fall 2013 的会员
CPSU-REGAN-F13S8G20
4 名成员
创作了10篇指南
Where do you get a replacement charging port at?
Evil Robot - 回复
Agree where can you get the port?
J-M. M. - 回复
添加评论
浏览统计数据:
过去的24小时: 6
过去的7天: 61
过去的30天: 291
总计 11,258
