跳转到主内容
更换微软Surface Pro 4的固态硬盘
你所需要的
  1. 更换微软Surface Pro 4的固态硬盘, 固态硬盘: 步骤 1 中的图像 1,2 更换微软Surface Pro 4的固态硬盘, 固态硬盘: 步骤 1 中的图像 2,2
    • 用蓝色撬棒工具将保护固态硬盘的金属罩边缘一周撬松。
  2. 更换微软Surface Pro 4的固态硬盘: 步骤 2 中的图像 1,2 更换微软Surface Pro 4的固态硬盘: 步骤 2 中的图像 2,2
    • 卸下固定固态硬盘的一颗1.0 mm梅花(Torx) T4螺丝。
  3. 更换微软Surface Pro 4的固态硬盘: 步骤 3 中的图像 1,2 更换微软Surface Pro 4的固态硬盘: 步骤 3 中的图像 2,2
    • 用蓝色撬棒工具或撬棒(Spudger)轻轻地撬起固态硬盘并用手指拿住它。向你的方向拉出就可以从设备上卸下固态硬盘了。
结论
参考步骤的相反顺序以重新安装你的设备。
92等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Z.Heng正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
StacyAnn Brown
于01/15/16注册
3,985 声望
创作了2篇指南
团队
Metro State, Team 1-3, Carpenter Spring 2016 Metro State, Team 1-3, Carpenter Spring 2016 的会员
MSU-CARPENTER-S16S1G3
2 名成员
创作了12篇指南
46指南评论
Can you add more SSD to the SP4??
dudu93lokao - 回复
Where can I buy a 1T that is compatible with it?
izou1838 - 回复
You can probably replace it with any 1TB NVMe M.2 SSD you find at any retailer. You can find plenty of those on Amazon.
Tip: Look for the performance models, such as Samsung PRO or similar.
Nmindz -
I would love to upgrade my storage while repairing my broken screen, does anyone know of which sdd would be compatible with my i7 8gb ram 256ssd right now? Does it have to be a samsung ssd or are there other options. Fairly new to computer repair here so would love some experienced advice thanks !
I would prefer a 1TB if possible but would settle for a 512 also.
bthonre - 回复
@bthorne As long as it's the same connection (not sure, but maybe you should look for NVMe M.2 SSD) it should work without problems. You should run a quick search on the internet to check if anyone has found some sort of "blacklisted" parts (some vendors such as Lenovo used to place some code in their firmware which would prevent the computer from booting with a "unauthorized" wireless card for example.).
However I think this is not the case with the Surface Pro 4 or the world would be at rage right now. Just look for any size NVMe M.2 SSD you think it would be fit (if you can afford, look for performance models such as Samsung PRO, there's a huge difference from the cheaper ones.). Hope it helps!
Nmindz -
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 199
过去 30 天: 962
总计 281,630
