跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
更换微软 Surface Pro 4 的电池
你所需要的
  1. 更换微软 Surface Pro 4 的电池, 给屏幕贴上胶带: 步骤 1 中的图像 1,3 更换微软 Surface Pro 4 的电池, 给屏幕贴上胶带: 步骤 1 中的图像 2,3 更换微软 Surface Pro 4 的电池, 给屏幕贴上胶带: 步骤 1 中的图像 3,3
    • 如果你的屏幕玻璃破裂,请保持进一步的破损,并在维修过程中用胶带粘住玻璃以防止人身伤害。
    • 将重叠的透明包装胶带条放在 Surface 的屏幕上,直到覆盖整个表面。
    • 这将保持包含玻璃碎片并在撬起和抬起屏幕时提供结构完整性。
    • 尽最大努力按照所述指南的其余部分进行操作。但是,一旦玻璃破碎,它可能会在你工作时继续破裂,你可能需要使用金属撬具将玻璃舀出。
    • 戴上安全眼镜以保护你的眼睛,并注意不要损坏 LCD 显示屏。
    If I have a screen protector on the screen should I remove it? Will it interfere with the heating process?
    IronJoker - 回复
  2. 更换微软 Surface Pro 4 的电池, 加热屏幕的右边缘: 步骤 2 中的图像 1,1
    • 加热 iOpener 并将其应用到 Surface 屏幕的右边缘两分钟。
    • 你可能需要重新加热并重新应用 iOpener 几次以使平板电脑足够温暖。遵循 iOpener 说明以避免过热。
    • 你也可以使用吹风机、热风枪或热板来加热 Surface。
    • 注意不要让 Surface 过热——屏幕和内置电池容易受到热损坏。
    • 如果屏幕已贴上胶带,请勿使用热板。
    I have done dozens of Surface Pro tablet repairs; if your screen is cracked or chipped AT ALL, you WILL make it worse. Plan on replacing it. Even if it's not cracked or chipped, the likely hood of removing this screen without damage (LCD separation or heat marks in the corners) is very low. Ive tried everything from hot plates to heat mats and the iOpener and nothing is reliable enough. I found that using my Warner heat gun set at 800*c and working on half an edge at a time with a LOT of 91% alcohol in a drip bottle along the edge, along with a very thin guitar pick (not the ones sold here, they are too thick) is the trick to loosening the glue. Work on the side and bottom first. The top is going to be the hardest as the adhesive will stick to the wifi/bluetooth antenna and you WILL tear them (Ive had to replace a fair amount of them). There's a delicate trick to doing it, but it's too hard to describe. If you've never done this repair before, I do not recommend it; find a professional.
    Gregg Stanley - 回复
    Hi, thanks for the information, Very valuable.
    I'm about to do this because my battery and fan aren't working.
    There's no way anybody can fix it properly near me. Got any other tip to try not to break the screen and or any flex?
    I've done works like this on small tablets and phones, but never this pc. I'll try to go slow.
    Thanks again for your experience information.
    Fernando A -
  3. 更换微软 Surface Pro 4 的电池, 注意粘合剂布局: 步骤 3 中的图像 1,1
    • 在继续之前,请注意屏幕粘合剂布局:
    • 这些区域仅包含粘合剂并且可以安全切割。 显示板和柔性电缆靠近边缘。小心切割,不要将撬片插入超过 1/8 英寸(3 毫米)。
    • 易碎的天线电缆位于屏幕的这一部分下方。
    • 仔细按照步骤 13 中的程序进行操作,以免损坏它们。粘合剂也是这里最厚的。
    The bottom red section is narrow and not as thick as the bevel indicates. I went too deep with my tool and cut through a ribbon thinking that I could send my tool as deep as the black bevel edge. its like half that.
    Jesse Fair - 回复
    I did a screenshot of this image to always see it while progressing through the steps and did exactly the same mistake. I read every comment in the steps below but yours only now :( On my device it's 5mm from the edge of the screen glass to the ribbon.
    WapitiSumpf -
    I cut through as well, but was able to carefully solder the edges together enough to make a connection - works fine.
    L Schaffer - 回复
  4. 更换微软 Surface Pro 4 的电池, 将三角撬片插入扬声器开口: 步骤 4 中的图像 1,2 更换微软 Surface Pro 4 的电池, 将三角撬片插入扬声器开口: 步骤 4 中的图像 2,2
    • 将三角撬片插入屏幕右上角的扬声器切口,然后在玻璃和扬声器格栅之间滑动撬片。
    • 不要将三角撬片插入深度超过 0.45 英寸(12 毫米)。将撬片插入太远可能会损坏 LCD。
  5. 更换微软 Surface Pro 4 的电池: 步骤 5 中的图像 1,2 更换微软 Surface Pro 4 的电池: 步骤 5 中的图像 2,2
    • 朝 Surface 底部旋转三角撬片,将其滑到扬声器开口的下边缘下方。
  6. 更换微软 Surface Pro 4 的电池, 切开屏幕胶: 步骤 6 中的图像 1,2 更换微软 Surface Pro 4 的电池, 切开屏幕胶: 步骤 6 中的图像 2,2
    • 将撬片向下滑动到 Surface 的右边缘,以切开屏幕下方的粘合剂。
    • 在整个过程的其余部分,如果你在滑动三角撬片时遇到很大的阻力,请停止并重新加热你正在处理的部分。用三角撬片施加太大的压力会使玻璃破裂。
    • 将此三角撬片留在右边缘,以防止粘合剂重新密封。
  7. 更换微软 Surface Pro 4 的电池: 步骤 7 中的图像 1,1
    • 重新加热你的 iOpener 并将其应用到 Surface 屏幕的底部边缘两分钟。
    • 如果屏幕已贴上胶带,请勿使用热板。
  8. 更换微软 Surface Pro 4 的电池: 步骤 8 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 8 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 8 中的图像 3,3
    • 将新的三角撬片插入右下角,然后将其围绕拐角向底部边缘滑动。
    • 请勿将三角撬片插入右下角周围的深度超过 0.25 英寸(6 毫米)。将撬片插入太远可能会损坏 LCD。
    • 沿着 Surface 的底部边缘滑动撬片以切开屏幕粘合剂。
    • 沿底部边缘插入三角撬片的深度不要超过 0.45 英寸(12 毫米)。
    • 将此撬片留在底部边缘以防止粘合剂重新密封。
    Yep. I scratched the corner of the LCD with the pick. Take the warning seriously folks! It’s really easy to do.
    Laurence Mayer - 回复
    The warning says to not insert it more than 12mm but it should be not more than 5mm. There is a ribbon/display connection at the bottom and i damaged it.
    WapitiSumpf - 回复
  9. 更换微软 Surface Pro 4 的电池: 步骤 9 中的图像 1,1
    • 重新加热你的 iOpener 并将其应用到 Surface 屏幕的左边缘两分钟。
    • 如果屏幕已贴上胶带,请勿使用热板。
  10. 更换微软 Surface Pro 4 的电池: 步骤 10 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 10 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 10 中的图像 3,3
    • 将新的三角撬片插入左下角,然后将其围绕拐角向左边缘滑动。
    • 小心在左边缘下方 2.5 英寸(65 毫米)下切割。不要在此处插入三角撬片超过 1/8 英寸(3 毫米)。显示器电缆位于挡板的这一部分附近,很容易损坏。
    • 穿过显示电缆区域后,你可以再次将撬片插​​入 0.45 英寸(12 毫米)。
    • 沿着 Surface 的左边缘滑动撬片以切开屏幕粘合剂。
    • 将此三角撬片留在左边缘以防止粘合剂重新密封。
  11. 更换微软 Surface Pro 4 的电池: 步骤 11 中的图像 1,1
    • 重新加热你的 iOpener 并将其应用到 Surface 屏幕的顶部边缘两分钟。
    • 沿此边缘的粘合剂最厚,你可能需要重新加热并重新应用 iOpener 几次以使平板电脑足够温暖。遵循 iOpener 说明以避免过热。
    • 如果屏幕已贴上胶带,请勿使用热板。
  12. 更换微软 Surface Pro 4 的电池: 步骤 12 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 12 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 12 中的图像 3,3
    • 用三角撬片将左角弄圆,然后沿着 Surface 的顶部边缘滑动。当三角撬片距离左边缘 2.75 英寸(70 毫米)时停止。
    • 外壳顶部边缘接下来的 6 英寸(15 厘米)被左右天线覆盖,天线位于外壳和屏幕边框之间。请仔细执行以下步骤以避免损坏天线。
    The right antenna is kind of P shaped (rotated 90° to the right) with the small end facing the middle. I'd suggest to stop at the middle when loosening the left antenna and to do the same thing coming from the right.
    WapitiSumpf - 回复
  13. 更换微软 Surface Pro 4 的电池: 步骤 13 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 13 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 13 中的图像 3,3
    • 易碎的天线电缆位于屏幕的顶部边缘下方。仔细遵循程序以避免损坏它们。
    • 在刚刚停止切割的屏幕下方插入拾取点。不要将三角撬片插入比挡板边缘更深的地方。
    • 小心地将三角撬片向右滚动,将撬片的长边压入挡板下方的屏幕粘合剂中,边走边切割粘合剂。不要沿着 Surface 边缘滑动三角撬片。
    • 重复此动作,将三角撬片的尖端插入你刚刚切割的位置,然后沿着 Surface 的顶部边缘向右滚动,直到截齿距离 Surface 的右边缘 2.5 英寸(64 毫米)。
    Bij mijn exemplaar bleek het onmogelijk om de bovenrand volgens de aanwijzingen los te maken. Ik heb de boel vele keren opgewarmd en ben meerdere malen met het plectrum langs de rand gegaan. Maar er beleef iets hardnekking vastplakken. Ik moest uiteindelijk de lijmverbindingen los maken zoals bij de andere randen. Achteraf bleek dat bij het gedeelte waar de antennes zaten het frame en het scherm volledig met elkaar verlijmd zaten met de antennes er tussen. Dat kostte me uiteindelijk de antennes. Gelukkig geen schade aan andere zaken. Niet zo'n grote ramp want ik kon nog antennes bestellen. Maar hou er rekening mee.
    EverB1 - 回复
  14. 更换微软 Surface Pro 4 的电池: 步骤 14 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 14 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 14 中的图像 3,3
    • 在天线上切割粘合剂(距左边缘 8.5 英寸或 22 厘米)后,沿表面的顶部边缘滑动三角撬片的其余部分,然后绕右上角切开任何剩余的粘合剂。
  15. 更换微软 Surface Pro 4 的电池, 打开 Surface: 步骤 15 中的图像 1,3 更换微软 Surface Pro 4 的电池, 打开 Surface: 步骤 15 中的图像 2,3 更换微软 Surface Pro 4 的电池, 打开 Surface: 步骤 15 中的图像 3,3
    • 非常缓慢地将屏幕组件从 Surface 外壳上提起。如果遇到任何阻力,请停下来检查所有粘合剂是否已分离。
    • 暂时不要移除屏幕。它仍然通过两条电缆连接到主板。
    • 使用三角撬片切开任何剩余的粘合剂。
  16. 更换微软 Surface Pro 4 的电池: 步骤 16 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 16 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 16 中的图像 3,3
    • 将屏幕组件的顶部从机箱中提起,同时将屏幕底部滑动到靠近主板显示接口的位置。
    • 轻轻地将屏幕放在外壳上,接口朝上。注意不要弄皱显示电缆。
  17. 更换微软 Surface Pro 4 的电池, 移除 EMI 屏蔽的技巧: 步骤 17 中的图像 1,3 更换微软 Surface Pro 4 的电池, 移除 EMI 屏蔽的技巧: 步骤 17 中的图像 2,3 更换微软 Surface Pro 4 的电池, 移除 EMI 屏蔽的技巧: 步骤 17 中的图像 3,3
    • 使用此方法移除维修期间所需的任何 EMI 屏蔽:
    • 使用一对斜角镊子的一个尖端从“牙齿”之间的间隙中撬起 EMI 屏蔽。
    • 在护罩周边的不同点重复此过程,直到它自由为止。
    • 尽量不要使防护罩变形太多——你需要在重新组装时重新安装它们。
    • 要重新安装,请尽你所能纠正任何变形,确保“齿”与主板上的边缘对齐,并按下 EMI 屏蔽的整个周边。
    • 确保所有“齿轮”都紧贴金属边缘,并且没有在 EMI 屏蔽下方弯曲。
  18. 更换微软 Surface Pro 4 的电池, 断开屏幕: 步骤 18 中的图像 1,3 更换微软 Surface Pro 4 的电池, 断开屏幕: 步骤 18 中的图像 2,3 更换微软 Surface Pro 4 的电池, 断开屏幕: 步骤 18 中的图像 3,3
    • 使用镊子移除覆盖显示电缆连接器的两个 EMI 屏蔽。
  19. 更换微软 Surface Pro 4 的电池: 步骤 19 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 19 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 19 中的图像 3,3
    • 用撬棒的扁平端撬起,将每条显示电缆从主板上断开。
  20. 更换微软 Surface Pro 4 的电池, 移除屏幕: 步骤 20 中的图像 1,1
    • 从 Surface 移除屏幕。
    • 在重新组装期间,请在此处暂停并按照本指南更换屏幕粘合剂。
  21. 更换微软 Surface Pro 4 的电池, 拆下天线支架: 步骤 21 中的图像 1,1
    • 使用 T5 Torx 螺丝刀卸下固定天线支架的四颗 4.5 毫米螺丝。
    This screw bit was not included in the battery replacement kit. Only Philips and Flathead were included.
    ComputerRepairAcct - 回复
    This Torx bit was not included in the battery replacement kit. Only a Philips and Flathead bit
  22. 更换微软 Surface Pro 4 的电池: 步骤 22 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 22 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 22 中的图像 3,3
    • 小心地卸下天线支架。
    • 小心不要卡住任何电缆。如果支架卡住,请勿将其强行推出。
    I had ripped through 2 of the 3 antennas when cutting through the top adhesive. Not sure how anyone removes this display without ruining at least one of them.
    I saw on Reddit this post: https://www.reddit.com/r/techsupportmacg...
    It works perfectly! My wifi was one that was cut. It’s now made of aluminum foil and is pulling down 147Mbps and pushing 80.88Mbps up.
    Joshua Snavely - 回复
    A ce stade il semble important de faire attention au micro. Pour ma part, il avait un résidu de colle entre celui-ci et le support à retirer.
    Jean-Claude Guinel - 回复
    On my device the mic is glued to the antenna board. I'd recommend to detach it's ribbon cable from the motherboard before removing the antenna board
    WapitiSumpf - 回复
  23. 更换微软 Surface Pro 4 的电池, 拆下CPU护罩: 步骤 23 中的图像 1,2 更换微软 Surface Pro 4 的电池, 拆下CPU护罩: 步骤 23 中的图像 2,2
    • 将一对尖头镊子的一个尖端插入覆盖散热器的 EMI 屏蔽角的间隙中。
    • 使用镊子尽可能多地将 EMI 防护罩从主板上撬开,而不要弯曲它。暂时不要移除它。
    • 在此防护罩上工作时,请注意不要用镊子刺破电池。
  24. 更换微软 Surface Pro 4 的电池: 步骤 24 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 24 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 24 中的图像 3,3
    • 在覆盖散热器的 EMI 屏蔽周边的各个位置重复最后一步。
    • 拆下 CPU 护罩。
  25. 更换微软 Surface Pro 4 的电池, 拧下散热槽: 步骤 25 中的图像 1,1
    • 使用 T3 Torx 螺丝刀从散热器上卸下两颗螺丝:
    • 沿着覆盖电池的矩形板顶部的一个 2.4 毫米螺丝
    • 沿着覆盖电池的矩形板底部一颗 2.2 毫米螺丝
    La première vis de 2,4 est une Torx 4, pour ce qui me concerne et non pas une Torx 3.
    Attention la deuxième vis est bien une TORX 3
    Remarque : La boite à outil "Essentiel electronics Toolkit - Grade B (ref EU145571-1)" ne contient pas l'embout T3
    Pour ma part j'ai utilisé donc le T4 en forçant un peu. Pas cool ;-(
  26. 更换微软 Surface Pro 4 的电池: 步骤 26 中的图像 1,1
    • 散热器牢固地粘附在风扇上。
    • 使用十字螺丝刀卸下固定风扇的三颗 2.4 毫米螺丝。
    • 使用 T5 Torx 螺丝刀卸下固定在风扇盖上的最后一个 4.4 毫米螺丝。
    These screws were in a different area on my Surface, Pro 4 bought at release. The fan was visible and attached to the heat sink. Remove the two torx screws on the fan housing. No need to remove the Philips head screws that secure the fan.
    mike_mcquillan - 回复
    My Surface Pro 4 has a fan here. Remove the screws around the fan and the whole heatsink including the fan can now be lifted off. DO NOT try and remove the heatsink from the fan as it is glued on.
    Andy - 回复
    Sorry I’m super brand new to the game. I don’t know the difference between 1.5mm Torx T4 and 3.0mm Torx T4. I look under tools I need to buy, and the tool kits only say Torx T4 or T5, without the milimeters dimensions.
    MInh Le Nguyen - 回复
    Je fais écho au commentaire de vennic, les longueurs indiqués en mm sont les longueurs des vis et n’impactent pas les tournevis à utiliser. Bien ranger les vis par longueur permets de mettre les bonnes vis aux bons endroits lors du remontage de l’appareil.
    Cajuteq -
    MInh Le Nguyen, the mm size refers to the length of the screws, not the size of the bit driver
    vennic - 回复
    Don’t forget to unplug the fan (if present) before yanking on the heat sink! It’s just a small grey clasp that needs to be lifted up.
    vennic - 回复
    The fan connector on mine was held in place by a white clamp on the side closest to the middle of the chassis. The long edge toward the middle flips up to vertical. That frees up the fan connector. Likewise for the black “wire” connector right beside it.
    David Hill - 回复
    As previously mentioned, the fan should be disconnected (look at step 36) BEFORE you remove the fan/heat sink assembly. Ive done DOZENS of these repairs and the fan has always been part of the heat sink assembly.
    Gregg Stanley - 回复
    I did all of this, now surface won't turn on. Any ideas?
    AlejandroC - 回复
  27. 更换微软 Surface Pro 4 的电池: 步骤 27 中的图像 1,1
    • 使用 T5 Torx 螺丝刀按以下方式卸下 CPU 周围的散热片螺钉,一次转动一圈,直到它们松开。
    • 螺丝 1
    • 螺丝 2
    • 螺丝 3
    • 螺丝 4
    • 在重新组装过程中,使用相同的方法安装这些螺丝,一次拧紧一圈,直到每个螺丝都紧贴。
    These screws were T5 Torx in mine, not T3 as in the instructions.
    Joshua Snavely - 回复
    T5 Torx screwdriver is correct.
    Majid Mazouchi - 回复
    What does one turn at a time mean?
    Fernando Ramirez - 回复
    One turn for the "red" screw, one for the orange, one for the yellow, then green and now again one turn red, orange, yellow, green ... This cross pattern distributes the pressure evenly .
    VauWeh -
    I think I need a T6 torx screw the screwdriver is not working for these screws
    Hassan Ali - 回复
  28. 更换微软 Surface Pro 4 的电池, 卸下散热器: 步骤 28 中的图像 1,2 更换微软 Surface Pro 4 的电池, 卸下散热器: 步骤 28 中的图像 2,2
    • 使用撬棒的平端轻轻地将散热器从 CPU 上垂直向上撬起。
    • 注意在拆卸过程中不要让散热器管产生凹痕或折痕。
    Hallo, kurze Frage ist der Kühlkörper also die Kupferstücke innen hohl?
    Peter Pyzik - 回复
  29. 更换微软 Surface Pro 4 的电池: 步骤 29 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 29 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 29 中的图像 3,3
    • 将撬棒的尖端插入风扇罩上的螺丝孔,然后向上提起以将其与风扇分开。
    • 风扇罩用轻质粘合剂固定到位。
    The fan should be disconnected (look at step 36) BEFORE you remove the fan/heat sink assembly. Ive done DOZENS of these repairs and the fan has always been part of the heat sink assembly.
    Gregg Stanley - 回复
    I'm not sure if adhesive was involved or if time and heat had caused the protective plastic film under the top section of fan to stick to the heat sink, but I had to use the Spudger to separate the heat sink from the plastic film to get it out.
    Ryan - 回复
    These instructions were correct for my Surface. The fan cover was attached to the heatsink but the fan was not.
    Eddie McGlone - 回复
  30. 更换微软 Surface Pro 4 的电池: 步骤 30 中的图像 1,1
    • 小心地卸下散热器。
    • 重新组装时,请务必正确清洁散热器和CPU,并涂上新的导热膏。
    Fan assembly may be taped to heat sink so fan screws and ribbon cable can be disconnected to remove as one with heat sink.
    Matt Dove - 回复
  31. 更换微软 Surface Pro 4 的电池, 取下电磁屏蔽罩: 步骤 31 中的图像 1,3 更换微软 Surface Pro 4 的电池, 取下电磁屏蔽罩: 步骤 31 中的图像 2,3 更换微软 Surface Pro 4 的电池, 取下电磁屏蔽罩: 步骤 31 中的图像 3,3
    • 将尖头镊子的一端插入覆盖摄像头排线接口的电磁屏蔽罩一角的缝隙。
    • 用钳子撬开电磁屏蔽罩,尽量避免其弯曲。
    • 避免其弯曲,因为你还需要将它装回去。
    • 将电磁屏蔽罩取下。
  32. 更换微软 Surface Pro 4 的电池, 断开摄像头: 步骤 32 中的图像 1,3 更换微软 Surface Pro 4 的电池, 断开摄像头: 步骤 32 中的图像 2,3 更换微软 Surface Pro 4 的电池, 断开摄像头: 步骤 32 中的图像 3,3
    • 用撬棒的尖端撬起,从主板上断开所有三根摄像头电缆。
    Missing the part to disconnect the ribbon to the left of the cameras, luckily, it disconnected by itself when I removed the motherboard.
    Marcus Stange - 回复
    Yes that's very important (white and blue socket on photo) !
    I forgot to reconnect it on reassembly (unluckily, it doesn't reconnect by itself ;o)
    Phil68 -
  33. 更换微软 Surface Pro 4 的电池, 断开按钮连接: 步骤 33 中的图像 1,3 更换微软 Surface Pro 4 的电池, 断开按钮连接: 步骤 33 中的图像 2,3 更换微软 Surface Pro 4 的电池, 断开按钮连接: 步骤 33 中的图像 3,3
    • 使用撬棒的尖端解锁固定音量/电源按钮电缆的 ZIF 接口。
    • 将音量/电源按钮电缆轻轻滑出 ZIF 接口。
    While you're here, you'll want to disconnect the ZIF connector directly opposite from this one, which can be seen in the lower right of these photos, nearer the camera cable connection points. The guide doesn't mention removing that cable, but you'll need it removed before you can lift out the motherboard.
    Nick - 回复
  34. 更换微软 Surface Pro 4 的电池, 断开左侧扬声器连接: 步骤 34 中的图像 1,2 更换微软 Surface Pro 4 的电池, 断开左侧扬声器连接: 步骤 34 中的图像 2,2
    • 在扬声器线和主板之间滑动撬棒的尖端,直到它靠在扬声器线接口上。
    • 小心地向上撬起扬声器线接口,将其从主板上断开。
    • 温柔点——扬声器线很脆弱。
    • 在重新组装过程中,将新的扬声器线束放在主板上的连接器顶部,然后用手指轻轻地将其笔直向下按以重新连接。
    1. the picture can be misleading
    2. use the flat end instead or you might damage the plastic part of the connector. see 更换微软Surface Pro 4的左侧扬声器
    wiu - 回复
  35. 更换微软 Surface Pro 4 的电池, 断开风扇及耳机插孔连接: 步骤 35 中的图像 1,3 更换微软 Surface Pro 4 的电池, 断开风扇及耳机插孔连接: 步骤 35 中的图像 2,3 更换微软 Surface Pro 4 的电池, 断开风扇及耳机插孔连接: 步骤 35 中的图像 3,3
    • 使用撬棒的尖端解锁风扇和耳机插孔 ZIF 接口。
    The fan should be disconnected when you removed the fan/heat sink assembly in Step 29 (which is NOT mentioned).
    Gregg Stanley - 回复
  36. 更换微软 Surface Pro 4 的电池: 步骤 36 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 36 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 36 中的图像 3,3
    • 使用撬棒的尖端轻轻地将风扇和耳机插孔电缆从其 ZIF 接口中滑出。
    Gregg Stanley - 回复
  37. 更换微软 Surface Pro 4 的电池, 松开风扇: 步骤 37 中的图像 1,1
    • 使用 T3 Torx 螺丝刀从风扇上卸下以下螺钉:
    • 一颗 2.5 毫米粗螺纹螺丝
    • 两个 2.4 毫米螺丝
    I didn't realize that one screw (red) here was different, and it looks like I put it in a different place during assembly, and the remaining screw, of course, did not hold. Be careful with the screws!
    I have a question: can I buy a set of these screws for Surface Pro 4 to change the spoiled ones? I noticed that sometimes they get damaged on top and it is difficult to screw them on afterwards.
    Olga Gold - 回复
  38. 更换微软 Surface Pro 4 的电池, 移除风扇: 步骤 38 中的图像 1,3 更换微软 Surface Pro 4 的电池, 移除风扇: 步骤 38 中的图像 2,3 更换微软 Surface Pro 4 的电池, 移除风扇: 步骤 38 中的图像 3,3
    • 使用撬棒抬起风扇的一侧。
    • 拿起风扇并将其卸下。
  39. 更换微软 Surface Pro 4 的电池, 拆下 EMI 屏蔽罩: 步骤 39 中的图像 1,3 更换微软 Surface Pro 4 的电池, 拆下 EMI 屏蔽罩: 步骤 39 中的图像 2,3 更换微软 Surface Pro 4 的电池, 拆下 EMI 屏蔽罩: 步骤 39 中的图像 3,3
    • 将一对镊子的一个尖端插入 EMI 屏蔽罩边缘的缝隙中,该缝隙覆盖 microSD 卡读卡器电缆和接口。
    • 尽量不要使防护罩变形太多——您需要在重新组装时重新安装它。
    • 取下防护罩。
  40. 更换微软 Surface Pro 4 的电池, 断开 microSD 读卡器连接: 步骤 40 中的图像 1,3 更换微软 Surface Pro 4 的电池, 断开 microSD 读卡器连接: 步骤 40 中的图像 2,3 更换微软 Surface Pro 4 的电池, 断开 microSD 读卡器连接: 步骤 40 中的图像 3,3
    • 使用撬棒的平端将 microSD 读卡器的接口从插槽中直接提起。
    • 向上提起 microSD 读卡器电缆,使其远离覆盖充电组件的 EMI 屏蔽。
    • 仅将电缆弯曲到接触 EMI 屏蔽所需的程度。请勿剧烈折叠或弯曲电缆。
    It's probably best to remove the microSD card reader at this point. The guide never states to remove it, but it eventually disappears from the photos. Two T5 screws are all that are holding it down. Easier to take those out and remove the assembly than to try to remove the EMI shield underneath while also holding the ribbon cable out of the way.
    Nick - 回复
    Not necessary to remove the reader. When reinserting the motherboard, you can slide it easily enough underneath it. It may make it easier, but isn't necessary.
    Gregg Stanley - 回复
    A ce stade, la nappe était coller sur le blindage. Pour ne pas trop plier la nappe, j'ai poussé la spatule. La colle n'était pas trop résistante.
  41. 更换微软 Surface Pro 4 的电池, 拆下 EMI 屏蔽罩: 步骤 41 中的图像 1,3 更换微软 Surface Pro 4 的电池, 拆下 EMI 屏蔽罩: 步骤 41 中的图像 2,3 更换微软 Surface Pro 4 的电池, 拆下 EMI 屏蔽罩: 步骤 41 中的图像 3,3
    • 将一对镊子的一个尖端插入覆盖充电组件电缆接口的 EMI 屏蔽边缘的间隙中。
    • 尽量不要使防护罩变形太多——你需要在重新组装时重新安装它。
    • 取下防护罩。
    Do steps 44 and 45 first to completely remove the SD card reader and cable. That way the cable is not in the way during these steps.
    Ryan - 回复
  42. 更换微软 Surface Pro 4 的电池, 断开充电端口连接: 步骤 42 中的图像 1,2 更换微软 Surface Pro 4 的电池, 断开充电端口连接: 步骤 42 中的图像 2,2
    • 使用撬棒的扁平端向上翻转固定充电组件电缆接口的固定锁。
    Take the two T5 Screws out of the SD card slot and remove it here as well. It's not mentioned later but it must be removed to slide the motherboard out easily.
    Dustin - 回复
  43. 更换微软 Surface Pro 4 的电池: 步骤 43 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 43 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 43 中的图像 3,3
    • 使用撬棒的尖端小心地推动接口的每一侧。
    • 从一侧交替到另一侧,轻轻地将接口从其插座中“移出”。
  44. 更换微软 Surface Pro 4 的电池, 移除 microSD 读卡器: 步骤 44 中的图像 1,1
    • 使用 T5 梅花头螺丝刀卸下固定 microSD 读卡器的两颗 3.1 毫米螺丝。
  45. 更换微软 Surface Pro 4 的电池: 步骤 45 中的图像 1,1
    • 移除 microSD 读卡器。
  46. 更换微软 Surface Pro 4 的电池, 断开柔性排线连接: 步骤 46 中的图像 1,3 更换微软 Surface Pro 4 的电池, 断开柔性排线连接: 步骤 46 中的图像 2,3 更换微软 Surface Pro 4 的电池, 断开柔性排线连接: 步骤 46 中的图像 3,3
    • 使用撬棒的尖端解锁处理器和右扬声器之间的 ZIF 接口。
    • 从 ZIF 接口断开排线。
    During reassembly, do this before installing the speaker.
    mattnovi - 回复
    This one broke during reassembling, so I could not fix the connector properly. I tried to find out what it is, but the only hint I found was, that it is some kind of antenna. I could not find out what kind of antenna. Anyway, after completion everything I needed worked fine: Bluetooth and Wireless LAN. I appreciate any hint about the purpose of this antenna.
    Josef Lichtscheindl - 回复
    That's my question too
    Mj Ro -
    Perhaps one of the two WiFi frequencies (2.4 or 5 GHz)?
    Phil68 -
  47. 更换微软 Surface Pro 4 的电池, 断开右侧扬声器的连接: 步骤 47 中的图像 1,2 更换微软 Surface Pro 4 的电池, 断开右侧扬声器的连接: 步骤 47 中的图像 2,2
    • 在右侧扬声器线和主板之间滑动撬棒的尖端,直到它靠在扬声器线接口上。
    • 温柔点——扬声器线很脆弱。
    • 在重新组装过程中,将新的扬声器线束放在主板上接口顶部,然后用手指轻轻地将其笔直向下按以重新连接。
  48. 更换微软 Surface Pro 4 的电池, 松开主板: 步骤 48 中的图像 1,2 更换微软 Surface Pro 4 的电池, 松开主板: 步骤 48 中的图像 2,2
    • 使用 T3 Torx 螺丝刀从风扇和主板上卸下以下螺丝:
    • 十颗 2.4 毫米螺丝
    • 两颗 2.2 毫米螺丝
    • 使用 T5 Torx 螺丝刀卸下固定右侧扬声器的两颗螺丝。
    • 一颗 4.2 毫米螺丝
    • 一颗 6.0毫米螺丝
    Use a T5 Torx screwdriver to remove screw in left and right speaker.
    Fredrik Strange - 回复
    BE CAREFUL! Use a T5 Torx screwdriver to remove an ADDITIONAL screw on the top corner of the right speaker. It should not take a tremendous amount of force to remove the speaker.
    John Ryan - 回复
    This screw is in the frame of the SP4. Mine was a T3.
    Rashad Parker -
    An additional screw has been marked up and added to the original photo regarding the issues with the right fan removal. Thanks to the community for the feedback!
    Clay Eickemeyer - 回复
  49. 更换微软 Surface Pro 4 的电池, 阻断电池连接器连接: 步骤 49 中的图像 1,3 更换微软 Surface Pro 4 的电池, 阻断电池连接器连接: 步骤 49 中的图像 2,3 更换微软 Surface Pro 4 的电池, 阻断电池连接器连接: 步骤 49 中的图像 3,3
    • 拆卸主板时,主板有可能与电池连接器短路。请阻断此连接以防止损坏。
    • 轻轻抬起主板左侧边缘。
    • 在电池连接器和主板之间插入一张扑克牌或类似物体。
    • 如果卡卡住了主板底部,请晃动卡,直到卡完全滑到主板底部。
    • 如果您要用新电池重新组装 Surface Pro,请现在就取出扑克牌。
    how will I know if the battery/ motherboard got short circuit? I did replace the battery without separating the connection and the surface have no power. Please advise
    T Nassar - 回复
  50. 更换微软 Surface Pro 4 的电池, 卸下右扬声器: 步骤 50 中的图像 1,3 更换微软 Surface Pro 4 的电池, 卸下右扬声器: 步骤 50 中的图像 2,3 更换微软 Surface Pro 4 的电池, 卸下右扬声器: 步骤 50 中的图像 3,3
    • 握住右侧扬声器箱的狭窄部分并将其稍微抬起。
    • 将右扬声器滑出机箱。
    • 拆下右扬声器。
    I didn’t read about the other T5 (about 6 mm) holding down the right speaker. It needs to be removed prior to this step.
    Laurence Mayer - 回复
    You also need to remove a screw in the top right corner of the speaker
    Daniel Bergstorm - 回复
    Yup there is an unmentioned t5 screw that the other comments catch
    Scott Smith - 回复
  51. 更换微软 Surface Pro 4 的电池, 取下主板: 步骤 51 中的图像 1,3 更换微软 Surface Pro 4 的电池, 取下主板: 步骤 51 中的图像 2,3 更换微软 Surface Pro 4 的电池, 取下主板: 步骤 51 中的图像 3,3
    • 卸下主板,首先抬起左侧,直到它大约成 30 度角。
    • 轻轻地将主板上的 I/O 端口从其开口中滑出,然后卸下主板。
    • 在重新组装过程中,请确保充电组件、左扬声器和三个摄像头电缆没有被卡在主板下方,然后再继续。
    There seems to be an additional ZIF connector by the Left most camera that also needs to be disconnected. Beware.
    Also, the micro SD reader obstructs a little bit (at bottom right )as you remove the motherboard.
    Scott Smith - 回复
  52. 更换微软 Surface Pro 4 的电池, 移除电池: 步骤 52 中的图像 1,1
    • 从电池连接器上取下扑克牌。
    • 加热你的 iOpener并将其覆盖在电池接口上两分钟来软化固定电池的胶。
    • 尽量不要让 iOpener 与电池接触。
    In previous steps an hairdryer, heat gun or hotplate were possible tools to attack the adhesive. Hotplate is a bit difficult here but what about the others? Can you use them here or is the iOpener the only option?
    Ing Lim - 回复
  53. 更换微软 Surface Pro 4 的电池: 步骤 53 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 53 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 53 中的图像 3,3
    • 从离电池最远的边缘开始,在电池接口下方滑动三角撬片以分离下方的粘合剂。
    • 确保电池接口完全脱离外壳。
  54. 更换微软 Surface Pro 4 的电池: 步骤 54 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 54 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 54 中的图像 3,3
    • 将 Surface 的顶部边缘向上支撑几英寸,使整个 Surface 向底部边缘倾斜。
    • 将粘合剂去除剂或高浓度(90% 或更高)异丙醇滴到电池顶部边缘下方。
    • 如果你使用粘合剂去除剂,请先按照这些准备步骤进行操作。
    • 让溶剂静置并浸泡在粘合剂中 2-3 分钟,然后再继续。
    Probably obvious to all except dolts like me… After soaking the batter in the solvent, set it flat again on the work surface before using the card to start working on the adhesive… I impatiently starting hacking on the adhesive while the Surface was still propped up… and promptly put a bend in the previously flat metal backplate.
    Laurence Mayer - 回复
    I tried multiple applications of iFixIt adhesive remover on my SP4 and it seems to be doing absolutely nothing. The glue won't budge even by millimeter
    Marcin Wisnicki - 回复
    It took 6 rounds and pretty serious push.
    Marcin Wisnicki -
  55. 更换微软 Surface Pro 4 的电池: 步骤 55 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 55 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 55 中的图像 3,3
    • 注意不要用工具刺破或弯曲电池 —— 刺破或弯曲的电池可能会泄漏危险化学物质或导致热事件。
    • 将塑料卡滑到电池顶部边缘的左侧下方。
    • 如果你在此过程中的任何时候遇到明显的阻力,请停下来,再涂抹一点粘合剂去除剂,然后等待它吸收。
    • 将卡从左上角电池下方的一侧滑到另一侧,以切开下方的粘合剂。
  56. 更换微软 Surface Pro 4 的电池: 步骤 56 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 56 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 56 中的图像 3,3
    • 将塑料卡完全插入左侧电池单元下方,然后向上撬动,使其与机壳分离。
    Take your time and do not use force. Soak repeatedly with IPA and move the card back and forward to free. I was a little forceful and the battery poach had visible signs from the card. No leak but better safe than sorry. I would also tape the batterie terminals , just in case.
    Cato Daykin - 回复
  57. 更换微软 Surface Pro 4 的电池: 步骤 57 中的图像 1,3 更换微软 Surface Pro 4 的电池: 步骤 57 中的图像 2,3 更换微软 Surface Pro 4 的电池: 步骤 57 中的图像 3,3
    • 将卡插入右侧电池单元下方,然后向上撬,使其与机壳分离。
  58. 更换微软 Surface Pro 4 的电池, 重新组装信息: 步骤 58 中的图像 1,2 更换微软 Surface Pro 4 的电池, 重新组装信息: 步骤 58 中的图像 2,2
    • 安装新电池后,请将扑克牌或类似物品放在电池连接器上,并将其留在原位,直到安装完主板。
  59. 更换微软 Surface Pro 4 的电池: 步骤 59 中的图像 1,1
    • 轻轻地将电池从外壳中取出。
    • 电池取出后请勿重复使用,否则会有潜在的安全隐患。
    • 安装新电池。
    • 剥离并清除底盘上的旧粘合剂。
    • 用高浓度酒精(90% 以上)和超细纤维布或无绒布清洁粘胶残留物。
    • 替换的胶条放在底盘上原来粘胶的位置,然后从电池连接器上取下衬垫。
    • 使用校准柱确定新电池的方向,并将其按紧到位。
    A la pose de la nouvelle batterie, la languette semble trop longue pour se positionner dans son emplacement (si l'on veut immédiatement faire correspondre tous avec les trous de positionnement). En fait :
    Poser et coller la batterie sans retirer la pellicule de l'adhésive de la languette.
    Ensuite, prendre soin de plier la languette de raccordement en suivant le profil de l'épaisseur de la batterie.
    Retirer la pellicule de l'adhésive de la languette qui, du coup, se présente bien à sa place .
结论
为达到最佳性能,校准您新安装的电池在完成本指南之后。
要重新组装您的设备,请按照相反的步骤操作。
将电子垃圾送到R2 或 e-Stewards 认证的回收商
维修结果不尽如人意?尝试基本故障排除,或访问[链接|https://www.ifixit.com/Answers/Device/Mi...|答案社区]寻求帮助。
149等其他人完成本指南。
由衷感谢以下译者:
en zh
92%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Sam Omiotek
于02/25/19注册
72,547 声望
创作了288篇指南
78条评论
thanks for this, use my surface pro 4 all the time, batteries are a disposable item and really need to be user replaceable
(if a company doesn't have a battery replacement service as good as apple's that is)
Bit of hassle but glad it can be done, zero idea where to get a replacement battery from though )-:
Adrian - 回复
found ! selling on ebay, look totally genuine too
Adrian - 回复
excellent presentation. I’d never try it myself. But I came here with what appears to be a battery problem. If you accept it as a bit offtopic: my battery icon reads 100%. when I am connected to my adaptor. When I remove the aadaptor plug, the screen goes to only a faint outline…to faint to read what % the battery is reading at. Any thoughts? I’m in a rural area of South West Thailand. So, v difficult to get to a reliable repair shop. Thanks !
paddy - 回复
This is probably too late for you now, you’ve probably solved this. But for anyone else experiencing this issue, it COULD be the power options. Windows automatically changes the screen brightness when you unplug, you could’ve accidentally set it right down. Go to Control Panel (Small Icons view) > Power Options. There should be options in there for what to do when removing the power adapter. Sorry I can’t be more specific, I’m on a desktop so it doesn’t have the right options to explain it fully.
dave.robilliard -
Thanks for the tutorial. Managed to break a display cable anyway T_T. Just broke itself… The rest was almost a piece of cake.
Seriously WHY so much shields on the motherboard, its insane… As a Mac Technician for almost two decades never saw such a mess (well except the powerbook 12” maybe).
That being said, I love my Surface !
huexley Yannick - 回复
I believe it is shielding EMF/EMI from the LCD, since everything is mounted right behind the LCDin extremely close proximity, electromagnetic interference can distort the picture, at least that’s the theory. On a Mac or traditional laptop, the LCD is well away from the current carrying portions of the laptop
Glen D -
+ 30 just for the 12” Powerbook comment!
lisagrant -
Anyone knows if the Surface Pro is able to run without battery? Connected to power supply of cause.
Søren B - 回复
I was not able to run it with the dead battery, even plugged in. It would start to boot, but once the OS kicked in with all the graphics, it would die. I managed to get Ubuntu Linux to work on it a little better, but I would not suggest it. It did not work well enough to use, and Ubuntu didn’t have drivers to run the pen or touch screen very well. Ultimately, replacing the battery worked, and I am now enjoying my Surface Pro 4 again!
Ray Sewell -
I would also be very interested to know. Any feedback from your question ?
Julien Krieger -
I have two under my belt now.
First was a broken screen, very difficult getting the screen off without leaving shards of glass attached to the adhesive. Replaced all adhesive with new.
Second was a battery that was expanding lifting the left side of the screen. Since the left side was lifted this made getting it started for easier. Screen came off intact. The speaker wire (Red/Black) is very fragile, I pulled the pins out of the holder when trying to remove. I was able to put them back. I would avoid it if you can as you only have to lift the mother board high enough to get the battery out and back in. There is enough slack, so I would recommend only removing if absolutely necessary. Followed tip to remove and replace thermal paste (Cleaner and paste (~$15). Had to replace the adhesive under the batter, just ran several stripes of the 2mm adhesive that I used for the display.
This site was a great guide.
mike_mcquillan - 回复
Thank you for this teardown and instructions! I just finished repairing my Surface Pro 4 after it sat for a year as a brick when the battery died. (I couldn’t get it to reliably boot up - and stay up - with a bad battery, even when it was plugged in.) I purchased all of the suggested equipment but ended up having to use a razor to shave off some of the aluminum case - near the indentation where the speakers are - in order to get the opening pick under the screen. The pictures were very helpful. Mine had a fan attached to the heat sink on the left side of the device, which meant there were a couple more screws to remove, but otherwise, the teardown was spot on.
Ray Sewell - 回复
Hi friend
Where I can get original battery for my Surface Pro 4?
Please give me link
Many thanks
Andread - 回复
Which part of the screen is the actual touch screen connection? I just did all of this and my touch is off a bit. I touch one place and it moves one other place. The pen isn’t accurate anymore either. My guess is it’s that housed connection on the back of the screen itself? I can take this thing apart again and just try it; just wanted to see if anyone had the exact connections..
Thanks
Ward Anderson - 回复
Kinda strange that they take the hear directly to the battery…. I might be paranoid but it smells a little fishy to me!
Also they should make battery replacements way easier! Surface pros are almost a disposable tablet. I didn’t buy one purely cause of this, but I love them so much!
Chloe Mcholoe - 回复
Super !!! Vielen Dank für die Anleitung. Ich habe mir zwar ein wenig mehr Zeit gelassen aber alles funktioniert ;-) der neue Akku läd wieder und mein Surface Pro 4 läuft wieder. Danke noch mal. Achso und es gab noch gleich eine größere SSD =)
Viele Grüße,
Michael
Michael Krömer - 回复
my pro 4 is not working with the replaced battery, only works when plugged in. please what can i do?
Samuel David - 回复
It was challenging for me to get the contacts in the right place. Aside from that, could be a bad diode. https://www.aonemobiles.com.au/2020/03/m...
vennic -
same here, changed the swollen battery, surface boots only with adapter and windows reports 100% full battery. Is there a calibration tool or something?
Philipp - 回复
Sounds like a bad voltage diode. I had similar problem replacing battery, screen and diode on mine.
Alfredo -
hallo, kann man das Sur face auch zur Reparatur schicken?
Johannes Baumgartner - 回复
I change the battery on mine (twice !!!) and it doesn’t charge the new battery.
However, the old battery is charged when plugged in.
If anyone has any info..
Thanks
WhuzDaMan - 回复
I seem to be having a similar issue. I have yet to find out what is wrong. If you ever find out what is wrong let me know; I have heard it could be a blown resistor but have yet to find one that does not give a voltage readout.
Logan Rocha -
Thanks for tutorial, but I wonder that if I remove battery and only use power adaptor ( while wait a new battery ) , I can use it as a pc ?
Tai Le - 回复
Be careful around the antenna when removing the display. I sheared the antenna sticker in half and needed to wait 30 days for a new antenna (25$).
Otherwise, the repair was very doable once the screen is off. The recommended adhesive (tesa), does make the display sit lower than original, giving the border a slight sharp edge all around. I would recommend a slightly thicker adhesive for reassembly.
Henri - 回复
Hallo,
kann man das Surface auch ohne Akku, nur mit dem Netzteil, betreiben ?
Achim Dresser - 回复
I have purchased and successfully follow the guide to replace my battery. But it seems that i am not able to restore charge amount of time when at 100% it’s only report 1 hour and a half approx.. when on the new battery. Is there any tool or calibration to restore this new battery that I purchased from ifixt to full capacity?.
It look the new battery is original here is what it shows using battery only power:
Description Value
Battery Name X910527
Manufacture Name SMP
Power State Discharging
Current Capacity (in %) 80.4%
Current Capacity Value 26,092 mWh
Full Charged Capacity 32,445 mWh
Designed Capacity 38,152 mWh
Battery Health 85.0%
Voltage 7,896 millivolts
Charge/Discharge Rate -6,480 milliwatts
Chemistry Lithium Ion
Low Battery Capacity (1) 983 mWh
Low Battery Capacity (2) 3,244 mWh
Number of charge/discharge cycles 229
Remaining battery time for the current activity (Estimated) 03:37:46
Full battery time for the current activity (Estimated) 04:30:48
Remaining time for charging the battery (Estimated)
lagarescarlos - 回复
Thanks for this information and useful comments.
I need to add that my Pro4’s heat tube has a cooling fan , so I needed to disconnect the fan cable connector by the power switch connector.
Mikio Kuge - 回复
ahhhh This has been a nightmare trying to perform. The shields are such a pain in the ass!
Matt Faherty - 回复
CAUTION! I completed this process to replace the battery on mine, and there is one IMPORTANT step that should be on this guide. Before removing the battery, a plastic card should be inserted between the battery contacts and the underside of the mainboard to isolate the battery from the contacts on the underside of the mainboard. When I was working the adhesive on the battery contacts from the chassis, the connections crossed and shorted something and burned out the IT8528VG chip. I contacted a repair shop regarding replacement of this part and they said it requires a hot air station to remove and micro soldering to replace. They said they see this common error when repairing. Now my Surface is a paperweight. Please add this crucial step to these instructions.
It is very frustrating to have performed this long, difficult process perfectly, with an intact Surface screen at the end, only to have irreparably destroyed it because of one important missing step.
Kyle Wagner - 回复
This can happen because of a blown battery.
Iam still searching why my pro4 isn't running from the battery only with the power connector.
philip oeh -
Appreciate the guide, this was an absolute pain to replace and I do NOT care for removing a battery as easy to damage as these when they’re mounted with such an obscene amount of adhesive. This guide allowed me to do so regardless, thanks.
SparkWorx - 回复
READ ALL STEPS AND COMMENTS FIRST BEFORE STARTING!!!
My surface would not charge the battery and would go dead if unplugged, then would go dead on reboot unless given a hard restart. New battery fixed the issue.
Step 18 is incomplete without reading the comments first, you could apparently brick your device if you don’t remove the old battery using a step that is not included in the guide. Also the guide gives NO guidance on detaching the battery contact strip from the shell, or how to properly install the new battery, which is odd, considering the title of the article. I (and others) wrote some comments on step 18 that should be helpful. The rest of the guide was great, but as is, incomplete.
vennic - 回复
I recently attempted this repair but with a new battery installed the device now won’t power on. The old battery was severely swollen and despite being as careful as possible I tore the outer foil wrapper and even tore the connector on the battery during removal (the battery did not smoke or seem that it had shorted). Regardless, it’s pretty clear that the device is shorted and is now bricked, right? Is there any remedy or is the motherboard “fried”?
I wish I would have seen the comments on step 18 about putting an insulator (paper) between the old battery and motherboard when removing. This may have saved my device.
Tabaplar - 回复
Just finished replacing the antenna and the battery on Surface Pro4. I highly recommend ignoring the steps to remove the battery without removing the motherboard (mb). Removing the mb is less difficult than trying to get the battery ribbon in and out. As many have learned, you can brick your mb, and, like me not get it aligned properly causing “no battery detected”. After removing the mb, I was able to realign the battery ribbon properly and all worked great. This video is great at removing the mb. Don’t worry about removing the buttons, left speaker, or SSD (they won’t interfere).
Youtube video number: n74Pc_luSGI (How to Take Apart the Microsoft Surface Pro 4)
Once mb is removed, remove the battery, and install the new battery, insuring the battery ribbon is on the plastic locator pin (not in instructions), place adhesive under ribbon to hold in proper place for contacts on the mb.
I purchased these and both work great:
Battery (Amazon ASIN): B08595GYBN
Antenna (Amazon ASIN): B08PV8SZ3R
bncote - 回复
Please add a disclaimer about how to AVOID shorting out the motherboard!!!
Ryan Sicard - 回复
This is some kind of sick joke, right? I just got through this and took out my battery. I do not know how the heck I’m going to get this thing back together.
What’s this paste where the old battery terminal connection was and how the heck am I supposed to get the new battery into place
Nicholas Redding - 回复
Did anyone have to use an adhesive to reseat the screen or did you just reheat the original adhesive?
Scott Evans - 回复
You need new adhesive
philip oeh -
Will a samsung 970 evo plus be fine to replace in the SP4? I know the 970 evo works fine, but just dont know the difference.
quinton - 回复
This worked great for me except I’m now having a problem with my computer not wanting to start up when I have the screen in place. If I hold it by the edges just above the computer, it boots up fine. There must be something touching that shouldn’t and cause it to turn off. Anyone have this problem or have an idea of how I can troubleshoot it?
Marianne Barrier - 回复
I would HIGHLY suggest removing the entire motherboard when performing this repair. It’s just another few screws and a few ribbon cables to take it out, and it will make removing and installing the new battery 10 times easier and allow you to align it properly. The guide is not kidding about the adhesive holding the back of the battery in place - it is very strong! I ended up using a heat gun on the back side of the device (underneath the kickstand) to help soften it a little bit, and an old credit card to help pry the battery out.
Cameron Bunch - 回复
A few thoughts, having done this over the weekend:
First, get yourself one of those sets of three plastic putty knives from the hardware store (the ones that have 3 different sizes). The middle size was the same size as the battery, and made removal of the battery while heating the back of the case a breeze.
Second, remove the tiny screws (two on each side) holding the kickstand to the hinges. It’ll let you fold it all the way back, which makes heating the backside much easier.
Third, while you’re in there, scrape out the copious and ill-applied thermal paste from on and around the CPU dies, and put on something decent. I did, and my Pro 4 is running much cooler now.
Last, TAKE YOUR TIME. I managed to remove and replace my screen without issue, but it took me a bit more than two hours to get it removed, and then remove the adhesive from the case and the back of the screen. I started in the upper-right corner, used the iFixIt Jimmy, and kept the heat gun around the bezel only, just slightly ahead of the Jimmy
tbldr - 回复
I have a Surface Pro 4 with a swollen battery. actually it’s the second time the battery has swollen. I have a question: Is it possible to remove the battery and just plug the device in whenever I want to use it? Does Surface Pro 4 work without battery?
محمد یوسفی‌شیرازی - 回复
It does work without the battery. I had no problem plugging it in and testing it without the battery connected.
NotABerger _ -
I just finished doing this repair yesterday and I have a few tips for people trying this repair. First of all, when removing the display, be really careful on the sides of the camera assembly, because this is where the antennas are located. These antennas are sandwiched between the adhesive that holds the display on and the frame of the device, so it is very easy to break them when you are opening up the device. I actually did end up breaking one of the antenna “flex cable” style pcb’s, but luckily I didnt break any of the traces and my antennas seem to work fine. Also, test the antennas, and make sure the device is able to charge at least a few percent before gluing the display back in place, as the battery might not be able to charge if the connectors to the battery aren’t all connected. This is a very difficult repair, and it feels like Microsoft tried to make the battery one of the most difficult parts to replace. Getting the display off is hard, but it is only the first step.
NotABerger _ - 回复
NotABerger _ - 回复
NotABerger _ - 回复
hooo, ok that is interested. Thanks for sharing. So the battery case empty ?
Julien Krieger -
Super erklärt und es funktioniert auch!! Schade dass wir so eine Wegwerfgesellschaft geworden sind, aber so kann man als Firma eben Umsatz machen! Top Anleitung!!
Michael Eller - 回复
“No battery detected” after install.. :-(
Sterling Baird - 回复
Habe den Akku erfolgreich getauscht und konnte das Surface anschließend auch wieder starten. Allerdings wird seitdem das Ladekabel (hat vorher einwandfrei funktioniert) nicht mehr erkannt. Jetzt habe ich das Problem dass der Akku nicht geladen wird und auch kein Netzbetrieb möglich ist. Damit ist nun ein neuer Akku drin, benutzen kann ich das Surface aber leider weiterhin nicht :-(. Hat jemand eine Idee was ich ncoh machen könnte?
Dominik - 回复
It’s nuts to me that, knowing full and well that blowing a backlight fuse is so %#*@ easy when accidentally hitting a power on input while servicing the device, that manufacturers willingly make the battery the last thing you can unplug. Great breakdown.
Davey Wavey - 回复
Thanks for the detailed tutorial.
IMHO it’s better to fully remove the motherboard (what I personnaly did), this has the following advantages:
- no shortcircuit risk when ungluing the battery flex-pcb.
- better access to the right side of the battery to remove it.
- easier to precisely stick the flex-pcb on the case after replacing the battery.
nietfou - 回复
Thanks for the tutorial. An excellent presentation on how to carefully access and replace the battery in a Surface Pro 4. I was able to complete this procedure without breaking the display glass and successfully replaced the battery in my old Surface Pro 4 with an iFixIt battery. I used iFixIt tools available from the iFixIt site. The only suggestion I would make would be to use a dental pick to remove the EMI shields from the Surface Pro. The supplied tweezers in the iFixIt tool kit was not strong enough and the tips bent. Also recommend carefully cleaning the glass surface of the display below the camera openings to ensure the cameras have a clear view once all the adhesive is removed, before the display is reattached to the case.
Robert Lusby - 回复
Eine kleine Verbesserung wäre, wenn man ein Foto von der Montage des Mainboards am neuen Display machen könnte.
Ansonsten ist das eine super Anleitung ! Weiter so :)
Tst - 回复
If you prefer to watch a video of disassembly/reassembly, I have successfully completed the whole process ;) You can see it here:
Microsoft Surface Pro 4 - screen bulge fixed, battery replaced, SSD upgraded! (https://www.youtube.com/watch?v=3eEbdCMr...)
So you can see non-broken screen removal and reattachment, motherboard removal, battery replacement, SSD replacement etc. I even managed to keep the screen intact after all was said and done! ;)
And as few people mentioned, avoid temptation to skip motherboard removal unless you know exactly what you’re doing (and if you’re reading this, you’re probably not). It is a bit more hassle to disconnect a bunch of stuff on the motherboard, but it makes it A LOT easier and more importantly SAFER to remove and reinstall the battery. Shorting motherboard is a real thing, and fixing that problem would be a whole lot more difficult than removing the motherboard. So just do it the right way, you will be thankful later ;)
Just Make It - 回复
It was described perfectly but my question is going to be related with what is the max capacity as MAH for the battery of my MSP4 to make the battery life last longer and stronger. I mean is it possible to make it bigger which will be helping us that we will be using it for more hours than before. If it is possible or if there is any other option to do it please just let me know. I do love my MSP4 and I just wanna use it more without the charger I will be able to use it more than 2 -3 hours for each time I turn it on. Even giving me more suggestions will be appropriate for making a new solution for my problem.
Nebil - 回复
Don't do this repair. It really isn't worth it. I managed to get everything done, but I was already replacing a faulty screen and figured "why not replace the battery while I'm in here?!"
Well... why not? Because it's way more work, everything is fiddley and easy to break, and the battery is a PAIN to get out.
Rob Traynere - 回复
I just replaced my battery in my Surface Pro 4. I followed an online replacement video that wasn't iFixit. Now my surface doesn't charge or power on. Reading some comments from others that are looking at the same problem after they changed their batteries, there appears to be a problem with Microsoft using a "Zero Ohm" resister that can be taken out by just lifting the board to remove the old battery. iFixit's video that shows removing the whole motherboard, I think that would have eliminated the problem I am now facing. Something should have been noted with the replacement battery that iFixit supplies, recommending that the entire motherboard be re-moved would have helped in avoiding this potential failure. I am onboard with the whole concept of 'Right To Repair', and the number of people that commented on the iFixit site that had the same scenario problem, makes me think that iFixit wasn't quick enough to acknowledge the problem or simply recommend with a note supplied with the replacement part.
David Laniewicz - 回复
hello, I was replacing the battery. when lifting up the motherboard this thing popped out of somewhere. and have no idea where this should go during assembly—image on the link. can someone please help me out?
https://imageshack.com/i/poQeg9g4j
Aleksandre Akhmeteli - 回复
It is the fixation on the heat dissipation rod from the battery to the CPU near the battery plate, see picture step 30 or the upper screw on step 25. It also happened to me :-).
A great detailed tear down description.
HOWEVER please note that on my Surface Pro 4 you can't lift the screen up as described as they are too short and it tore one on the ribbon cables! A better way is to lift the screen up just enough to prise off the aluminum covers and disconnect the cable connectors first.
Mike Lagan - 回复
Thanks for this tutorial, really great! I managed to replace the battery and the device works just fine after.
Anyway, everybody talks about sustainability these days. The battery in the MS surface is a great example about how to avoid sustainability and make "one-way" devices... :-/ . I like working with the surface a lot, but the experience of changing the battery leaves a bit of an aftertaste on Microsoft's hardware.
Hello.
I completely agree with this comment about programmed obsolescence. It's obvious that the MS Surface tablet was designed to be almost impossible to dismantle and therefore to be throw away in the event of a breakdown. Despite this precious tutorial and the use of the iOpener, it was impossible for me to remove the touch screen without breaking it. I had the same misfortune with the wifi and Bluetooth antennae on the top part, the metal strips were completely amalgamated with the adhesive and I had to sacrifice them to remove the pieces of glass. So, a word of warning to the next (very) brave troubleshooting adventurers: replacing the battery on a pro surface is a very very... delicate operation. Good luck!
Phil68 -
Mein altes Akku hatte sich 2 Wochen vor der ersten Klausurphase so stark aufgebläht, dass sich das Display in der unteren linken Ecke gelöst hat und ich war von meinem Microsoft Surface Pro 4 angewiesen.
Dank der detaillierten Anleitung mit Bild und Text, konnte ich leichter den Akku mit weiteren Toolkits von iFixit mit einer Wärmeleitpaste wechseln.
Die Tipps waren auch in der Anleitung sehr hilfreich.
Es sind schon 2 Monate nach dem Akku-Wechsel und ich habe bis jetzt keine Probleme feststellen können.
Das einzige (was ich auch verkraften kann) ist, dass mein Tablet nach herunterfahren sich trotzdem entlädt. Ich weiß nicht woran das liegt.
Aber unter Einstellung > System > Strom und Akku sieht man eine ausführliche Information der Akkustände in der letzten 24h.
Man kann sehen wieviel Prozent in der Stunde (z.B. im ausgeschalteten Zustand) entladen wird.
So weiß ich ungefähr wann das Tablet (im ausgeschalteten Zustand) wieder aufgeladen werden muss.
Vielen Dank an dem iFixit-Team😀👍🏼⭐⭐⭐⭐⭐
Kaveh Kazerani - 回复
This was an excellent guide. I was able to replace the battery and it's charging now and no broken or lost parts! For some unknown reason, the Surface could not find the battery the first time I installed it. I did it over and made sure the battery connection was properly located and I bent the motherboard prongs a little for better contact. Not sure which one was the issue but it works now. It was not too difficult to remove the glass since the swollen batteries had completely unfastened the left side of the screen. I used a heat gun and took it easy. The correct labeling and storage of the small screws was easy using a magnetic board. The Ifixit kit had all the needed supplies. I bought a static strap and the magnetic board to make the job easier. Hopefully I can get a few more years out of it. The Surface Pro 4 works really well as a travel computer.
Victor Bertolina - 回复
Spoke too soon. Battery charges to 100% but surface only operates when plugged in with charging cable.
I had the expanded batteries that made me think screen removal was fairly easy and I was already over the hump. I had not read the warnings about the antenna tape so I was not as delicate there as I should have been. Made it through the disassembly and reassembly. Struggled with one micro connector to the right of the camera bank that I may not have needed to unplug - I don't think it was in the instructions and I don't have any confidence in the way it went back in.
Unit went back together, booted from battery, recognized me (camera works), but now no keyboard/touchpad. Not sure if these keyboards are bluetooth, but I couldn't get it to recognize a bluetooth speaker either. Touch works fine. The pen works fine. Wifi is fine.
Primarily wanted to rescue it as a drawing tablet, and avoid buying an iPad. This may work as a drawing tablet for a bit but it wasn't a pleasant experience and I wouldn't risk it again.
Jeff Oestreich - 回复
Hola. buenas. Hace 1 año se me infló la batería de mi surface pro 4. Hace un año la envié a reparar, pero decidí por diversas circunstancias usarla sin bateria. Ahora quiero ponerle una nueva. Mi pregunta es ¿puedo ponerle alguna otra batería de mayor capacidad?
Muchas gracias.
Hello. hello good. 1 year ago the battery of my surface pro 4 inflated. A year ago I sent it in for repair, but decided for various reasons to use it without a battery. Now I want to put a new one on it. My question is, can I put another battery with a higher capacity?
Thank you very much.
Ruben Quintana - 回复
getting the screen off w/o breaking it or damaging the ribbon cables on either side of the camera are the most difficult parts of this process.
Paul Nozicka - 回复
Thank's a lot ! I would never try without this tutorial. A bit long but successfull: new battery, new SDD and Windows 11 installed.
Dam - 回复
The tutorial was easy to follow. The overall experience to me was pretty good. Most of it not difficult at all. Having the right tools helps ofcourse. I only encountered one problem and that had nothing to do with the quality of the tutorial. When releasing the screen from the frame I had problems in the antenna area. At the end I had no other choise then use some more force then I wanted to. Ending up destroying the antenna. When the screen was seperated I could see why. Parts of the antenna were glued to the screen and parts of the antenna were clued to the frame. No amount of heat was enough to get the antenna released from the screen. And even after the screen was released I had difficulties cleaning the screen from the remains of the antennas.
EverB1 - 回复
Thank you for this guide. I was successful in getting the new battery installed. I received the Surface Pro 4 from my boss because it was getting retired. It now will gain a second life in the field during our customer estimates. I had two problems. The adhesive torn the copper on the wifi antenna cover in two spots. Instead of replacing it I used silver glue over the torn area and it's working fine. The wifi ribbon I screwed up and bought a replacement, along with a new SSD since I had it opened up. I've built computers since I was 13 in the early 90s. Not a hard fix but a time consuming one.
Trent - 回复
A great set of instructions! I had only one slip up (foil antenna cut- but was able to fix this). It took 3 hours to disassemble, remove battery and clean. Took a lunch break, then 1 hour to reassemble, test and reattach screen. The touch screen was intact, but the touch portion was damaged as the battery had swelled and bent the screen. I now have a small band near the screen top that does not respond to touch. everything else works as it did when new. Thanks to you and well done!
L Schaffer - 回复
Excellente aide au démontage de la Surface, très bien pour la qualité du texte et ds photos ! bravo !
Dominique Delagree - 回复
Followed this guide, laboriously and slowly, and successfully replaced the battery. I went around the screen with my pick and a hot air gun, very slowly working out the adhesive. I did break one of the antenna, but replaced it with some copper tape I had in the shed (slug tape!). Not the easiest thing to do, but I couldn't have done it without this guide. Thanks!
David Fairclough - 回复
添加评论
浏览统计数据:
过去 24 小时: 123
过去 7 天: 1,003
过去 30 天: 4,340
总计 376,235
