简介
维修须知:
- 这次更换绝对是一个挑战。除非对自己的 DIY 能力十分自信,否则最好还是交给一个更专业的维修机构,甚至微软原厂。
- 确认更换屏幕的版本。大多数设备使用V1.1版本的屏幕和触摸单元。如果更换的屏幕和出厂使用的版本不同,维修后可能会出现新的问题。
- 最重要的是,金属外壳是不能弯曲的。由于外壳为屏幕留出的凹槽误差范围极小,一旦金属外壳出现弯曲,新安装的屏幕将无法正常放入。尝试小心地将金属外壳掰回去,或是交由专业人员处理。
你所需要的
如要重新组装设备,请按照本指南的逆序操作。组装完成后可能需要更新固件、驱动,或是完全重置设备。
149等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
52指南评论
Hi,
I live in the UAE and I have a broken screen. The screens work just no touch screen. Getting it replaced over here will cost a lot. Over 600 usd. The screen will cost the most.
Instead, I thought about buying the screen and digitizer myself and have someone fix it here for me. This will he relatively cheaper.
How do I know which screen and digitizer to buy? And where can I buy one from? I found the v1.1 on etrade supply but I don't know how reliable this site is.
Can you please guide me?
Thanks
JuliusCes
what do you ended up doing? same problem here and i dont want to crack it open just to check the screen model
lautaro -
i’ve just changed my screen with mixed results. I tried to remove the cracked screen in case it turned out to be something other than v1.1. in fact I ended up chipping off hundreds of shards around the edges until it finally came out. It was a 1.1, hooray! So then I plugged in the replacement and it works great, but I’m afraid to tape it in permanently because I damaged all three antennae which I didn’t anticipate being buried in the adhesive along the top edge. As I was chipping glass and peeling pieces out I didn’t realize those were prices of the antennae I was tearing out. Wi-Fi speed test runs fine in my shop where I’m close to the access point. I‘m trying to decide whether to order the antennae to replace just in case. I’l need those tiny torx drivers to remove screws.
Contrary to the photos above I didn’t need to remove screws to remove the display. The connector is actually the one just below the one indicated -the smaller one that has no screw.
Happy fixing!
Look up the correct replacement screen by including your Surface model # in the query. Find your model # under the kickstand.
Model # location image:
Many thanks for the reply. I ended up getting the screen fixed via Microsoft. It turns out that they have a service center in the UAE. Something that not even the UAE microsoft store was aware of!
Cheers,
Julius
