简介
指导将会告诉你如何安全的移除你的Microsoft Surface Pro 3电池。先移除你的触控板和显示器在跟随指导移除你的电池
你所需要的
反向跟随这些说明安装你的设备
60等其他人完成本指南。
由衷感谢以下译者:
83%
CoikVollin正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
34指南评论
Do you have to glue everything back together? Do you heat the parts back up to get the glue to stick again?
I slowly removed the old adhesive watching out for glass shards. A spundger and razer blade didn’t really help. In the end, I just used my fingernail and finger to roll the adhesive like I was removing rubber cement. It too about 30 minutes but I was able to get it cleaned off. I replaced the adhesive with 2 mm Tesa tape. This worked great.
Has anyone ever successfully opened a surface pro 3 without breaking the screen?
Yes I have successfully open the surface pro with out breaking the screen by using a heat gun, the islack and the using the picks around the screen as anchors, then use the islack as you will use it to replace the screen in the iphone. It takes time and patience and a lot of heat. It took me 25 minutes to remove the screen with out breaking it.
Only wizards can accomplish this task without breaking the screen. Yes the screen must be reheated for the glue to stick again. A simple fix to avoid all of these problems is to switch to Apple products.
Erik Snyder - 回复 分享
