跳转到主内容
Microsoft Surface Pro 2 Motherboard Replacement
你所需要的
  1. Microsoft Surface Pro 2 Motherboard Replacement, LCD Display: 步骤 1 中的图像 1,2 Microsoft Surface Pro 2 Motherboard Replacement, LCD Display: 步骤 1 中的图像 2,2
    • To avoid electrical shocks, unplug and turn off your Surface Pro 2 before proceeding.
  2. Microsoft Surface Pro 2 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Avoid any skin or eye contact with the heating pad or heating gun because they may cause bodily harm.
    • Using a heating pad or heating gun, heat the edges of the screen to soften the glue. This area extends roughly one inch from the edge of the device.
    • The glue is under the darker border of the device display.
  3. Microsoft Surface Pro 2 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using a plastic opening tool and a suction cup as needed for leverage, gently insert one edge of the opening tool under the corner of the screen.
    • If the tool does not easily slide under the screen, return to heating before proceeding.
    • Slowly work the tool around the entire edge of the screen.
  4. Microsoft Surface Pro 2 Motherboard Replacement: 步骤 4 中的图像 1,3 Microsoft Surface Pro 2 Motherboard Replacement: 步骤 4 中的图像 2,3 Microsoft Surface Pro 2 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Detach the orange cables that connect the screen to the motherboard by pulling on the small tabs. Using the nylon spudger, release these cables.
    • Please note the third small connector in red.
    • Allow the glue to cool before letting it come into contact with any other surface.
  5. Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Microsoft Surface Pro 2 Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Make sure that the front-facing camera is completely disconnected, and then remove the plastic bracket.
    • Remove the 22 screws on the bezel.
    • Remove the left and right brackets; the left has 16 screws and the right has 15 screws.
    • The three different torx screws used are T3, T4, and T5.
  6. Microsoft Surface Pro 2 Motherboard Replacement: 步骤 6 中的图像 1,3 Microsoft Surface Pro 2 Motherboard Replacement: 步骤 6 中的图像 2,3 Microsoft Surface Pro 2 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Once the brackets are removed, set them aside.
    • The motherboard itself also has screws.
    • Remove the 25 screws of varying sizes that attach the motherboard to the back plate.
    • View the attached photo of a screw diagram to help keep track of your screws.
  7. Microsoft Surface Pro 2 Motherboard Replacement: 步骤 7 中的图像 1,3 Microsoft Surface Pro 2 Motherboard Replacement: 步骤 7 中的图像 2,3 Microsoft Surface Pro 2 Motherboard Replacement: 步骤 7 中的图像 3,3
    • You have now completely removed the motherboard, and it should look like the pictures shown.
    • Be sure to be cautious with all the connections with the cables on the motherboard.
结论
2等其他人完成本指南。
团队
USF Tampa, Team 6-2, Remmell Fall 2016 USF Tampa, Team 6-2, Remmell Fall 2016 的会员
USFT-REMMELL-F16S6G2
4 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 58
总计 6,206
