跳转到主内容
修复你的物品
维修的权力
商店
简介
Use this guide to replace the kickstand for your Surface.
  1. Turn the tablet over so the screen is facing down. Pull up on the bottom corners to open the stand.
    • Turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    • Remove the stand by unscrewing the two 5.08mm T5 Torx screws located on the left and right sides.
    • Gently wiggle the stand until the lever in the middle is free, releasing the stand.
结论
13等其他人完成本指南。
Kevin Hua
于2013年01月11日注册
1,443 信誉积分
创作了3篇指南
团队
Cal Poly, Team 17-23, Forte Winter 2013 Cal Poly, Team 17-23, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G23
5 名成员
创作了12篇指南
Where do you get the replacement kickstand from?
Ray - 回复
is this compatible with surface pro 1 ?
arqueiro - 回复
Do you offer a replacement kickstand for the surface rt 2?
allie - 回复
Does this replacement kickstand come with the screws also?
Andrea Thompson - 回复
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 40
过去的30天: 192
总计 38,243
