跳转到主内容
Microsoft Surface Book Keyboard Back Panel Replacement
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Microsoft Surface Book Keyboard Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Flip the keyboard over so you can see the back panel.
  2. Microsoft Surface Book Keyboard Back Panel Replacement: 步骤 2 中的图像 1,2 Microsoft Surface Book Keyboard Back Panel Replacement: 步骤 2 中的图像 2,2
    • Insert the plastic opening tool in the crevice between the panel and the keyboard.
    • Apply some pressure and lift up so that the back panel is pried away from the keyboard.
    • The panel is glued down on the inside so this may require some force to lift away the panel.
    • Continue to lift until the panel is completely separated from the keyboard.
    • The panel is still attached to the keyboard by a ribbon cable so only lift the panel a few inches.
  3. Microsoft Surface Book Keyboard Back Panel Replacement: 步骤 3 中的图像 1,1
    • Lift the panel away with the ribbon cable still attached and set aside the panel so that you can work on other components.
结论
团队
Cal Poly, Team 20-3, Livingston Fall 2016 Cal Poly, Team 20-3, Livingston Fall 2016 的会员
CPSU-LIVINGSTON-F16S20G3
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 261
