此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
动态照片拍摄
成为一个动作片主人公!本指南需要一些图片,这些图片能够更好演示如何进行某些特定操作。
需要更好的图片
更好的照片将改善本指南。请帮助拍摄,编辑,或上传新的图片!
需要更多图片
更多的图片将使本指南的操作过程一清二楚。
缺少的步骤
糟糕!本指南目前缺少一些重要的步骤。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
5等其他人完成本指南。
5指南评论
The first paragraph of this Surface Book 2 battery replacement guide is:
"This guide explains how to replace the battery in the Microsoft Surface Book 2 15". It requires the motherboard replacement guide as a prerequisite guide, which is a very difficult guide to follow without breaking the laptop."
The first paragraph of the motherboard replacement guide is:
This guide is used to explain how to open up the tablet portion of the Microsoft Surface Book 2 15 and gain access to the motherboard. The motherboard of the Microsoft Surface Book 2 15 has a majority of the cables for parts that can be replaced on it.
Does this mean that I have to go through all the replacement motherboard steps and replace the motherboard before replacing the battery?
Nicholas Law - 回复 分享
You won't need to replace the mobo, but yes, it looks like you'll have to remove it. This guide is pretty confusing right now IMO
darth mango - 回复 分享
I also find it rather confusing.
Thanks darth mango.
Is it true that the battery in the Surface Book 2 has frequently failed completely?
No charging possible, always 0%.
When a battery ages, you can still charge it to 100%.
Very fast (bad), but “full”.
A total failure would rather be the battery management system.
I wonder if there were also failures of the charging current to the battery, i.e. a defect on the circuit board of the tablet screen.
That would be annoying, of course, because you can't just fix the fault by replacing the battery.
But replacing the entire battery would also be annoying if only the BMS is defective.
All you need is a replacement with comparable values and size, which you solder into the center of the battery.
And what about the assembly?
Are there adhesive strips in this form?
Or should you just use BT-7000 liquid glue?
I bought this for a Samsung Galaxy Note-9 to seal it watertight again after replacing the USB port.
Meine Akkus sind plötzlich auf 0% hängen geblieben. Aufladen nicht mehr möglich. Nur noch Netzbetrieb meines Surface 2. Schade. Akkutausch zu teuer.
