跳转到主内容
Microsoft Natural Multimedia Keyboard disassembly and cleaning
你所需要的
  1. Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 1 中的图像 1,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 1 中的图像 2,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning, Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 1 中的图像 3,3
    • A guide showing how to disassemble and clean a Microsoft Natural Multimedia Keyboard.
    • You will need a spudger to remove the keys. An IC mounting tool can be helpful in replacing them.
  2. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 2 中的图像 1,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 2 中的图像 2,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 2 中的图像 3,3
    • Use the flat end of a spudger to pop the keys off the keyboard.
  3. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 3 中的图像 1,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 3 中的图像 2,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 3 中的图像 3,3
    • Wider keys will have a retaining bar, take note of how they come off to make reassembly easier.
    • Continue removing keys.
  4. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 4 中的图像 1,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 4 中的图像 2,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 4 中的图像 3,3
    • Remove the 10 screws from the bottom of the keyboard.
    • Remove the upper button assembly.
  5. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 5 中的图像 1,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 5 中的图像 2,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 5 中的图像 3,3
    • Use the tip of a spudger to push the upper button assembly buttons out from the back.
  6. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 6 中的图像 1,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 6 中的图像 2,3 Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 6 中的图像 3,3
    • Remove the flexible keypad from the key caddy assembly.
    • The key caddies can be washed in the sink.
  7. Microsoft Natural Multimedia Keyboard disassembly and cleaning: 步骤 7 中的图像 1,1
    • The keys can also be washed.
    • Remove the metal retaining clips before washing to prevent rust.
结论
9等其他人完成本指南。
asvnix
于11/18/12注册
274 声望
撰写一个指南
3条评论
Thank you so much! I had never done this before and was very confused by the retaining bar.
Des Blackoak - 回复
I’ve had this keyboard since it was released and it just recently started having key sticking issues, so I opted to follow this guide and was pleasantly surprised at how well it worked. Thank you for this and I hope to get another 15 years out of it.
Suggestions:
1) Instead of manually cleaning, put the keys into a clear mesh bag and into the dish washer or washing machine.
2) Spray metal retainer bars with WD-40 and wipe off to help further prevent rust.
3) Let the keys and caddies sun dry for the day to ensure they do not retain any water after cleaning.
Thomas K - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 47
总计 13,065
