跳转到主内容
Microsoft Lumia 640 LTE Front Screen Replacement
你所需要的
  1. Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 步骤 1 中的图像 1,3 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 步骤 1 中的图像 2,3 Microsoft Lumia 640 LTE Front Screen Replacement, Take off the back cover: 步骤 1 中的图像 3,3
    • Back comes apart easily
  2. Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: 步骤 2 中的图像 1,2 Microsoft Lumia 640 LTE Front Screen Replacement, Peeling of the tape: 步骤 2 中的图像 2,2
    • Peel the tape from left to the right.
    • Under the tape there is a hidden screw.
  3. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the back screws.: 步骤 3 中的图像 1,1
    • Take these screws out, and remember organize your screws so you know where they are going when you are putting the phone back together.
  4. Microsoft Lumia 640 LTE Front Screen Replacement, Take out the side screws.: 步骤 4 中的图像 1,1
    • Turn the phone on its side and there are two (2) more screws that needs to be taken out.
  5. Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 步骤 5 中的图像 1,3 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 步骤 5 中的图像 2,3 Microsoft Lumia 640 LTE Front Screen Replacement, Release the back from the screen.: 步骤 5 中的图像 3,3
    • Be careful of the top left corner of the phone, the connecting cable is sitting there.
    • The green arrows indicates where the cable is, so be careful
  6. Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: 步骤 6 中的图像 1,2 Microsoft Lumia 640 LTE Front Screen Replacement, Disconnect cables: 步骤 6 中的图像 2,2
    • disconnect the two connectors here: Green, and Red.
  7. Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 步骤 7 中的图像 1,3 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 步骤 7 中的图像 2,3 Microsoft Lumia 640 LTE Front Screen Replacement, Removing camera/speaker: 步骤 7 中的图像 3,3
    • Carefully remove the cable.
    • Top two arrows indicate Camera, and chip. Button arrow indicate the way it is easiest to get the cable off.
  8. Microsoft Lumia 640 LTE Front Screen Replacement, Last step, remove the speaker.: 步骤 8 中的图像 1,1
    • The speaker comes out really easy
    • Do not fear, it is not attached by a cable but only glue.
结论
28等其他人完成本指南。
Nick Johansen
于10/09/15注册
1,991 声望
创作了2篇指南
18条评论
Guys your awesome. I just replaced a cracked screen and it only cost me the price of a new one.
Ron Hudson - 回复
I'm happy to help, please let me know if there was any step that was hard to understand.
Nick Johansen - 回复
Hi guys microsoft lumia 640 front screen cracked where can i have it replaced plz
Delmark Lawrence - 回复
With the ease of replacing these screens and the availability of the part you could attempt it yourself as it is a simple process and a very rewarding one at that!! :) :p
Cory Hibbin -
thanks nick, do you have a picture of the device without speaker and ready to reassembling?
Labartsara Sara - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 26,226
