简介
微软 Lumia 535
RM-1090 / RM-1091/ RM-1089 / RM-1092
如何拆解更换逻辑板。
你所需要的
视频概述
断开
触摸屏排线
LCD 显示屏 排线
充电接口 排线
同轴天线 排线
移除两颗T4梅花螺丝。
Take care when removing the coax connector. Mine was very tight and I managed to disconnect the coax cable from the connector. Phone is now in the bin :-(
keithellis - 回复
Also, when removing the charging dock board flex cable, the connector has a black lock arm. Remove the foam pad and tape to reveal the lock. Gently ease the lock arm up then ease the flex out.
keithellis - 回复
移除逻辑板。
With the camera/logic board removed then don’t forget to remove the other end of the charging dock board flex cable from the charging board. When reassembling I found it awkward to hold the protective black guard over the flex out of the way when sliding the end of the ribbon into the replaced charging dock board: combination of tweezers and fingernail required.
要重新组装您的设备,请按照本指南的相反顺序进行操作。
8等其他人完成本指南。
由衷感谢以下译者:
83%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
How can I add additional sensors- the gyroscope & compass chips on this logic board?
microsoft lumia 535 chargeing ic complete
my Microsoft lumia 535 chargeing ic complient main mother board lo problem
My microsoft mobile 1090 is not displaying apps but on backlight
Please what can I do to it?
