跳转到主内容
Microsoft Lumia 535 Logic board Replacement
你所需要的
视频概述
  1. Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: 步骤 1 中的图像 1,2 Microsoft Lumia 535 Logic board Replacement, Back Cover / Rear Case: 步骤 1 中的图像 2,2
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Logic board Replacement: 步骤 2 中的图像 1,2 Microsoft Lumia 535 Logic board Replacement: 步骤 2 中的图像 2,2
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Logic board Replacement: 步骤 3 中的图像 1,3 Microsoft Lumia 535 Logic board Replacement: 步骤 3 中的图像 2,3 Microsoft Lumia 535 Logic board Replacement: 步骤 3 中的图像 3,3
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Logic board Replacement, Logic board: 步骤 4 中的图像 1,3 Microsoft Lumia 535 Logic board Replacement, Logic board: 步骤 4 中的图像 2,3 Microsoft Lumia 535 Logic board Replacement, Logic board: 步骤 4 中的图像 3,3
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Logic board Replacement: 步骤 5 中的图像 1,3 Microsoft Lumia 535 Logic board Replacement: 步骤 5 中的图像 2,3 Microsoft Lumia 535 Logic board Replacement: 步骤 5 中的图像 3,3
    • Insert wisdom here.
结论
8等其他人完成本指南。
ZFix
于12/09/13注册
191,308 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
4条评论
How can I add additional sensors- the gyroscope & compass chips on this logic board?
Abinash Pal - 回复
microsoft lumia 535 chargeing ic complete
Sunitha Kunapareddi - 回复
my Microsoft lumia 535 chargeing ic complient main mother board lo problem
My microsoft mobile 1090 is not displaying apps but on backlight
Please what can I do to it?
aribasoyeifeoluwa - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 5,931
