跳转到主内容
Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement
你所需要的
视频概述
  1. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: 步骤 1 中的图像 1,2 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Back Cover / Rear Case: 步骤 1 中的图像 2,2
    • Turn off the phone.
    • Remove the battery and any SIM and memory cards.
  2. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 2 中的图像 1,2 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 2 中的图像 2,2
    • With a screwdriver Torx T4 remove the 9x screws.
  3. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 3 中的图像 1,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 3 中的图像 2,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 3 中的图像 3,3
    • With a plastic opening tool separate the back cover from the middle frame.
  4. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: 步骤 4 中的图像 1,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: 步骤 4 中的图像 2,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Logic board: 步骤 4 中的图像 3,3
    • Disconnect:
    • Touch screen flex cable
    • LCD Display flex cable
    • Charging Dock board flex cable - remove the foam and tape, then flip up the black lock before easing out the flex.
    • Coaxial antena cable - take your time here, be sure to pull the metal connector and not the cable or you risk pulling the cable from the connector.
    • Remove the 2x Torx T4 screws.
  5. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 5 中的图像 1,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 5 中的图像 2,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 5 中的图像 3,3
    • Insert wisdom here.
  6. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: 步骤 6 中的图像 1,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: 步骤 6 中的图像 2,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement, Charging Port Dock and Microphone Flex: 步骤 6 中的图像 3,3
    • Disconnect the coaxial antenna cable.
    • The cable is attached at several points to the frame and to the board. Gently remove it.
  7. Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 7 中的图像 1,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 7 中的图像 2,3 Microsoft Lumia 535 Charging Port Dock and Microphone Flex Replacement: 步骤 7 中的图像 3,3
    • The board is glued to the main frame by adhesive tape.
    • Use a hot gun or hair dryer and warm the board.
    • Now you can easy separate the board from the main frame.
    • For the separation process use only plastic tools.
结论
16等其他人完成本指南。
ZFix
于12/09/13注册
187,973 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
311 名成员
创作了1,196篇指南
一条评论
where can i get charging port for microsoft lumia 540
saurabh pawar - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 17
总计 14,599
