简介
Microsoft Lumia 535
RM-1090 / RM-1091/ RM-1089 / RM-1092
如何拆卸手机,更换破碎,破损的显示屏或触摸屏玻璃。
!!!触摸屏有不同的版本:
• CT2S1973FPC-A1-E
• CT2C1607FPC-A1-E
版本号印在排线上.
你所需要的
视频概述
断开
触摸屏排线
LCD 显示屏 排线
充电接口 排线
同轴天线 排线
移除两颗T4梅花螺丝。
Take care when removing the coax connector. Mine was very tight and I managed to disconnect the coax cable from the connector. Phone is now in the bin :-(
keithellis - 回复
Also, when removing the charging dock board flex cable, the connector has a black lock arm. Remove the foam pad and tape to reveal the lock. Gently ease the lock arm up then ease the flex out.
keithellis - 回复
移除逻辑板。
With the camera/logic board removed then don’t forget to remove the other end of the charging dock board flex cable from the charging board. When reassembling I found it awkward to hold the protective black guard over the flex out of the way when sliding the end of the ribbon into the replaced charging dock board: combination of tweezers and fingernail required.
将触摸屏装回开始重新组装手机。
就这样。
你成功了吗?
要重新组装您的设备,请按照本指南的相反顺序进行操作。
50等其他人完成本指南。
由衷感谢以下译者:
100%
Leon赵国鑫正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
19条评论
hi
cane you tell me price of out glass of lumia 535 duol sim please ?!
omarkhalil - 回复
I want to join in your team
Saikrishna - 回复
Hi,How to know which the versions touch screens my phone is Lumia 535 RM-1089 , please?
You need to open phone, cant tell otherwise.
Is the phone memory gets deleted after replacement??
is display assembly of microsoft lumia 540 can be replaced with display assembly of microsoft lumia 535
Nice write up. It's the surest way of doing it right.
FAIYAZ AHMAD Microsoft 535 skirt top
hi
I just have the glass broken, Display works properly. How can i only replace the glass?
Great guide! It was on point!!
