跳转到主内容
Microsoft Lumia 435 Touch screen Glass Only Replacement
你所需要的
视频概述
  1. Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: 步骤 1 中的图像 1,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: 步骤 1 中的图像 2,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Switch off the phone.
    • Remove the battery and any inserted SIM and memory cards.
    • Use a screwdriver Torx T6 and remove the 4x black screws.
  2. Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 2 中的图像 1,3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 2 中的图像 2,3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 2 中的图像 3,3
    • There are several plastic locking clips hold the back cover to the frame.
    • Use a tool with a sharp edge to unlock them and a plastic tool to separate the back cover.
  3. Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: 步骤 3 中的图像 1,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: 步骤 3 中的图像 2,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Logic board: 步骤 3 中的图像 3,3
    • Unhook:
    • the touch screen flex cable
    • the LCD Display flex cable
    • Use a plastic tool lift up and remove the Logic board.
  4. Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 4 中的图像 1,2 Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 4 中的图像 2,2
    • This is the logic board / main board - a front and rear view.
  5. Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: 步骤 5 中的图像 1,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: 步骤 5 中的图像 2,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, LCD Display: 步骤 5 中的图像 3,3
    • The Display metal shield is locked to the frame by 4x locking clips.
    • Use a tool with a sharp tip and careful unlock them and remove the shield.
  6. Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 6 中的图像 1,3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 6 中的图像 2,3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 6 中的图像 3,3
    • The display is stuck tovthe touch screen glass with a double-sided adhesive tape.
    • Use a hair dryer or hot air gun and worm the glass to make adhesive soften.
    • Distort the frame a little and use a thin plastic tool to separate the display from the frame.
  7. Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 7 中的图像 1,1
    • The display is very fragile, do the separation very carefully.
  8. Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: 步骤 8 中的图像 1,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: 步骤 8 中的图像 2,3 Microsoft Lumia 435 Touch screen Glass Only Replacement, Touch screen Glass Only: 步骤 8 中的图像 3,3
    • Put some transparent scotch tape to prevent the glass from shattering.
    • Warm the glass for a minute to make adhesive soften.
    • Start the separation from the middle of the frame, where the contact area is smaller.
  9. Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 9 中的图像 1,3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 9 中的图像 2,3 Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 9 中的图像 3,3
    • When you finished with the separation the glass, clean the frame from the old adhesive.
    • Install the new touch screen and start to reassemble the device.
  10. Microsoft Lumia 435 Touch screen Glass Only Replacement: 步骤 10 中的图像 1,1
    • That's all.
结论
5等其他人完成本指南。
ZFix
于12/09/13注册
191,368 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,468篇指南
一条评论
Is the lcd adhesive just on the edges of the lcd or covering the entire thing?
Addison Ramsey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 22
总计 5,282
