跳转到主内容
加入维修社区 - 创建账户
Microsoft Band 2 Defective Battery Connection/Ribbon Replacement
你所需要的
  1. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement, Defective battery connection/ribbon: 步骤 1 中的图像 1,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement, Defective battery connection/ribbon: 步骤 1 中的图像 2,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement, Defective battery connection/ribbon: 步骤 1 中的图像 3,3
    • Carve away *almost* all of the rubber of the straps. (Leave the rubber surrounding the battery/heart rate clasp end.)
  2. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 2 中的图像 1,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 2 中的图像 2,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 2 中的图像 3,3
    • Partly dissassemble the battery clasp end: pry up the silver clasp face that is taped down, unscrew the four T3 Torx , remove that cover, remove the battery
  3. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 3 中的图像 1,2 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 3 中的图像 2,2
    • Remove the plastic 'sandwiching' the ribbon as it travels into the clasp end, with a Dremel or knife. (Picture 2 illustrates the removed plastic.)
  4. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 4 中的图像 1,2 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 4 中的图像 2,2
    • Sand the ribbon to expose the conductors on both sides. Be careful to keep the insulator in between the two conductors intact, so they don't short. The second picture shows a 10x image of the layers of copper and insulator.
  5. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 5 中的图像 1,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 5 中的图像 2,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 5 中的图像 3,3
    • Wrap the repaired break with insulating tape. Sand away outer insulator on both sides to make soldering locations for jumper strips.
  6. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 6 中的图像 1,1
    • Use Sugru to wrap/stabilize the repair and integrate it into the clasp end's rubber.
  7. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 7 中的图像 1,1
    • Drill two holes into clasp-end plastic tabs, and two holes on each side of watch face's 'shoulders', as anchor points for thread to fasten strap leather. (Hole locations are the black dots on the gold metal near the silver casing.)
  8. Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 8 中的图像 1,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 8 中的图像 2,3 Microsoft Band 2 Defective Battery Connection/Ribbon Replacement: 步骤 8 中的图像 3,3
    • Build new leather straps; fasten using thread through holes & glue.
结论
Your Band 2 should (!) hold a charge now. Not sure how durable this repair is.
2等其他人完成本指南。
Kirk McDermid
于08/20/17注册
171 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 3,484
