跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will show you how to remove the Microsoft Band 2 battery in case the battery dies out, a common problem in the Band 2.
  1. Peel back the metal cover on the end of the watchband.
    • Peel back the metal cover on the end of the watchband.
  2. Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the  metal cover plate.
    • Use a T3 Torx screwdriver to unscrew the four 6 mm screws on the corners of the metal cover plate.
  3. Manta 螺丝刀工具包
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  4. Use the plastic opening tool to pry off the metal cover plate.
    • Use the plastic opening tool to pry off the metal cover plate.
  5. Detach the black ribbon cable by using the tweezers. Detach the black ribbon cable by using the tweezers.
    • Detach the black ribbon cable by using the tweezers.
  6. Detach the orange press-fit (or "pop") connector by using the tweezers. Detach the orange press-fit (or "pop") connector by using the tweezers.
    • Detach the orange press-fit (or "pop") connector by using the tweezers.
  7. Pry out the battery using the plastic opening tool. Pry out the battery using the plastic opening tool.
    • Pry out the battery using the plastic opening tool.
结论
20等其他人完成本指南。
Chris Syracuse
于2017年02月20日注册
637 信誉积分
创作了3篇指南
团队
USF Tampa, Team S1-G5, Leahy Spring 2017 USF Tampa, Team S1-G5, Leahy Spring 2017 的会员
USFT-LEAHY-S17S1G5
3 名成员
创作了5篇指南
My Band 2 is not charging and it showing empty battery with AC plugin Icon, but after longtime its not charging . In this case if I replace the battery is it will work or not?
Notes: did not turn on.
Tanvir Ahmed Howlader - 回复
Microsoft band guide works well - I managed to remove the battery easily - but where do I get a new battery from ?
Margo Bowes - 回复
TWO WORDS:
THANK YOU!
(A++++)
Somebody know where to buy battery replacement?
I Want Fix IT - 回复
The only place i found was ebay:
ftlay - 回复
Batteries can be found on ebay. I was surprised to see the band come back to life. I found the “pop” connector difficult to align properly. Almost lost patience with it. Got it on, reassembled and it powered up.
Dwight Gaut - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 8
过去的30天: 52
总计 11,476
