跳转到主内容
Michael Kors Watch Link Band Replacement
你所需要的
  1. Michael Kors Watch Link Band Replacement, Link Band: 步骤 1 中的图像 1,1
    • Place the watch on your wrist and determine whether links should be added or removed.
    • If watchband needs to be expanded, approximate the number of links required.
  2. Michael Kors Watch Link Band Replacement: 步骤 2 中的图像 1,3 Michael Kors Watch Link Band Replacement: 步骤 2 中的图像 2,3 Michael Kors Watch Link Band Replacement: 步骤 2 中的图像 3,3
    • Set the watch on the block holder.
    • Ensure the arrows located on the links are pointing downward.
  3. Michael Kors Watch Link Band Replacement: 步骤 3 中的图像 1,1
    • When removing damaged or extra links, hold one end of the pin pusher against the pin to be removed.
    • Strike the other end of the pin pusher with the metal side of the watch hammer until the pin slides out.
    • Two pins hold each link to the band, so two pins must be removed per link.
  4. Michael Kors Watch Link Band Replacement: 步骤 4 中的图像 1,1
    • Discard the broken links or save any extra links that you remove.
  5. Michael Kors Watch Link Band Replacement: 步骤 5 中的图像 1,2 Michael Kors Watch Link Band Replacement: 步骤 5 中的图像 2,2
    • To add links to the watchband, position the watch on the block holder with the arrows facing upward.
    • Insert pins into the holes that connect the new link to the rest of the watchband.
    • Use the soft side of the hammer to strike the pin down.
  6. Michael Kors Watch Link Band Replacement: 步骤 6 中的图像 1,2 Michael Kors Watch Link Band Replacement: 步骤 6 中的图像 2,2
    • Lastly, make sure that all the pins joining the links are secured in place.
结论
8等其他人完成本指南。
10指南评论
How do I replace a broken link when it's the very first link that connects the band to the actual watch?
Karen Perri - 回复
How can I puchace the first link on my Michael kors ceramic watch
melissa.costello31 -
I need first link to attach to micheal kors ceramic white watch
I have this exact problem. Anyone have an answer???
Andrea Sherville -
The lady when I bought my watch at the mall told me that Michael Kors will give you two free links I'm trying to figure out how I can go about getting that
Claudia Mead - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 55
过去 30 天: 226
总计 80,667
