跳转到主内容
MiJia Bluetooth Thermometer (2 Battery) Replacement
你所需要的
  1. MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: 步骤 1 中的图像 1,3 MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: 步骤 1 中的图像 2,3 MiJia Bluetooth Thermometer (2 Battery) Replacement, Open the back plate: 步骤 1 中的图像 3,3
    • Insert the flat side of your spudger or your finger nail into the crack located the back-bottom of the device.
    • While inserted, use gentle force to lift the bottom up, then, use a Opening pick or your finger to remove all the clips.
    • The bottom should detach.
  2. MiJia Bluetooth Thermometer (2 Battery) Replacement, Change Battery: 步骤 2 中的图像 1,1
    • You need a spare CR2032 battery.
    • Remove the old battery and attach new battery from top.
结论
You might need to wait few minute before the temperature synced up.
2等其他人完成本指南。
6512345
于09/06/24注册
133 声望
撰写一个指南
1指南评论
Thanks bro, that was really helpful and presented in a simple and easy way!
Kira Great - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 279
