跳转到主内容
Meural Canvas MC227 Wi-Fi Module Replacement
你所需要的
  1. Meural Canvas MC227 Wi-Fi Module Replacement, Remove the rear cover, locate the mainboard.: 步骤 1 中的图像 1,3 Meural Canvas MC227 Wi-Fi Module Replacement, Remove the rear cover, locate the mainboard.: 步骤 1 中的图像 2,3 Meural Canvas MC227 Wi-Fi Module Replacement, Remove the rear cover, locate the mainboard.: 步骤 1 中的图像 3,3
    • Remove all the philips screws off the rear cover.
    • Approach the mainboard, remove all the connectors and the screws and free the mainboard.
    • Wi-Fi module is shown in the last photo, it is AP6255.
    • You need to desolder the Wi-Fi module and replace it.
  2. Meural Canvas MC227 Wi-Fi Module Replacement, Desolder the Wi-Fi module with hot air gun.: 步骤 2 中的图像 1,2 Meural Canvas MC227 Wi-Fi Module Replacement, Desolder the Wi-Fi module with hot air gun.: 步骤 2 中的图像 2,2
    • Cover the rest of the board with kapton tape to prevent heat damage.
    • Using hot air gun and plenty of flux heat the module until it is moving.
    • Remove the Wi-Fi module with tweezers.
    • Clean the area with solder wick and flux.
    • Apply fresh solder on the pads.
  3. Meural Canvas MC227 Wi-Fi Module Replacement, Resolder the new Wi-Fi module.: 步骤 3 中的图像 1,3 Meural Canvas MC227 Wi-Fi Module Replacement, Resolder the new Wi-Fi module.: 步骤 3 中的图像 2,3 Meural Canvas MC227 Wi-Fi Module Replacement, Resolder the new Wi-Fi module.: 步骤 3 中的图像 3,3
    • Place the new Wi-Fi module and solder it with hot air gun and plenty of flux.
    • Pay attention to positioning the module.
    • Check the soldering from all corners and eliminate shorts.
    • Admire your work.
  4. Meural Canvas MC227 Wi-Fi Module Replacement, Reassemble the unit and enjoy.: 步骤 4 中的图像 1,1
    • Clean and reconnect your mainboard on the device.
    • While I was there, I repainted the frame into matte white, looks way nicer.
    • Reconnect all cables and connectors.
    • Restart and connect your Meural Canvas to the network.
    • Now your Meural Canvas will have no problems connecting Wi-Fi now.
    • Enjoy beautiful art on a beautiful screen!
结论
Koray
于03/05/17注册
1,395 声望
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 89
