跳转到主内容
MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement
你所需要的
  1. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: 步骤 1 中的图像 1,2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement, Battery Contacts in Remote Controller: 步骤 1 中的图像 2,2
    • Turn the remote controller over to the back.
  2. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 2 中的图像 1,1
    • Slide the battery cover off in the direction of the arrow on the cover.
  3. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 3 中的图像 1,2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 3 中的图像 2,2
    • Remove the batteries (2 AA).
  4. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the four screws located in the four corners of the back of the remote controller.
    • Screw length is 6 mm.
  5. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 5 中的图像 1,2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 5 中的图像 2,2
    • Separate the two halves of the remote controller.
  6. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 6 中的图像 1,2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 6 中的图像 2,2
    • Lift the metal tab until it is straight and can move through the slot in the battery compartment.
  7. MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 7 中的图像 1,2 MerchSource the Black Series Boat Racer Battery Contacts in Remote Controller Replacement: 步骤 7 中的图像 2,2
    • Flip the remote controller to the external side and slide the metal connections in the battery compartment straight up.
    • Slide the new connections straight down into the slot in the battery compartment, flip to the internal side, and bend the metal tab until it's parallel with the battery compartment.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 208
