当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
You can now see the trunk actuator. It connects to the lock mechanism by the metal rod with a spring.
To remove the actuator begin by removing the two hex head screws. They should be 8mm heads.
Then disconnect the two vacuum lines, making note of their orientation. One is for lock (red stripe), one is for unlock (green stripe).
Finally, pull the metal armature of the actuator off of the lock mechanism. It pulls off in the direction of the vacuum actuator body.
这个步骤还没有翻译 帮忙翻译一下
Remove the actuator from your car. Inspect it for obvious leaks.
On this actuator you can see that the outer diaphragm, on the lock side, is very obviously torn and so the actuator should be replaced.
If there were no obvious tears or cracks in the outside of the actuator you will need to use your vacuum pump with gauge to test the lock and unlock sides of the actuator.
5等其他人完成本指南。
一条评论
Step 1 should be: Getting into the trunk with faulty vacuum actuator. Is there a way to do this without destroying the left lens assembly?
