跳转到主内容
Mercedes W123 Sway Bar Link Replacement
你所需要的
  1. Mercedes W123 Sway Bar Link Replacement, Sway Bar Link: 步骤 1 中的图像 1,2 Mercedes W123 Sway Bar Link Replacement, Sway Bar Link: 步骤 1 中的图像 2,2
  2. Mercedes W123 Sway Bar Link Replacement: 步骤 2 中的图像 1,1
    • You can see here the sway bar link where it attaches to the sway bar. It's hidden partially behind the brake shield. It's tricky to take a good picture of...
    • The threaded portion of the link goes through a hole in the sway bar end and is held in place by a nut.
  3. Mercedes W123 Sway Bar Link Replacement: 步骤 3 中的图像 1,1
    • At the bottom, it screws in to the hub assembly.
    • View this video to hear what a bad sway bar link sounds like when you move the sway bar around. If yours sounds like this is definitely time to replace it.
  4. Mercedes W123 Sway Bar Link Replacement: 步骤 5 中的图像 1,1
    • Remove the nut from the top of the sway bar link using a 17 mm socket to turn off the nut while holding the inside of the sway bar link joint with an open end 17mm wrench.
    • Then use the open end 17mm wrench to loosen the bottom joint of the sway bar from the hub assembly.
    • You'll then be able to remove the sway bar link for inspection. Save the nut and any washers as the new links do not come with replacements.
  5. Mercedes W123 Sway Bar Link Replacement: 步骤 6 中的图像 1,3 Mercedes W123 Sway Bar Link Replacement: 步骤 6 中的图像 2,3 Mercedes W123 Sway Bar Link Replacement: 步骤 6 中的图像 3,3
    • Pictured are example of the joints on the two sway bar links that were removed from this 1985 300D. Each one is split or even missing.
    • You can see how this exposes the joint to moisture, dust, and road debris; this quickly ruins the joint.
    • Watch this video to see how loose the bottom joint on this sway bar link was. It was half of the culprit for the clunking. The other side was just as bad.
    • Install the new sway bar links by following these steps generally in reverse.
    • View this video to hear the difference with new links. Or, perhaps more accurately, not hear anything at all!
结论
9等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,010 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,521篇指南
3条评论
Great photos and videos. Good job. Thanks.
Pat OBrien - 回复
You're welcome! This is definitely one of those repairs that are 1) easy and 2) provide a LOT of immediate tangible benefit. It's super annoying driving around with bad sway bar links.
Nicolas Siemsen -
How to get it off the hub assembly in the first place ? do I have to remove the brake disks ? and how much do I need to torque them
adelkheir - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 24
过去 30 天: 85
总计 11,079
