跳转到主内容
Mercedes W123 Radiator Hose Replacement
你所需要的
  1. Mercedes W123 Radiator Hose Replacement, Radiator Hose: 步骤 1 中的图像 1,1
    • Begin by draining your radiator of coolant as [无效指南链接]. You will not need to drain the block for this process.
    • As always, never work on your coolant system when it is hot. This is very very dangerous.
  2. Mercedes W123 Radiator Hose Replacement: 步骤 2 中的图像 1,2 Mercedes W123 Radiator Hose Replacement: 步骤 2 中的图像 2,2
    • Find your upper coolant hose connection at the upper driver's side of the radiator.
    • Loosen the hose clamp on this end of the hose.
  3. Mercedes W123 Radiator Hose Replacement: 步骤 3 中的图像 1,1
    • Follow this hose to the top of the engine block, where it enters the thermostat housing.
  4. Mercedes W123 Radiator Hose Replacement: 步骤 4 中的图像 1,1
    • Then use a hose clamp removal hook or other appropriate tools to work around under the edge of the hose. This will help break them free; they often stick to the necks they attach to over time.
    • Pull the hose off fully on both ends.
  5. Mercedes W123 Radiator Hose Replacement: 步骤 5 中的图像 1,1
    • Continue by loosening the clamp on the lower radiator hose where it connects to the thermostat housing.
  6. Mercedes W123 Radiator Hose Replacement: 步骤 6 中的图像 1,1
    • Then go underneath the car and loosen the clamp on the lower radiator hose where it connects to the radiator.
    • Remove the hose in the same manner you did the upper hose.
    • Now replace both hoses, and secure with hose clamps. Replace the hose clamps with new ones if they were difficult to open due to corrosion or stripped screw heads.
    • Finish by filling the system with coolant and bleeding the system as [无效指南链接]
结论
4等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,284 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 29
总计 6,368
