跳转到主内容
Mercedes W123 Fuel Injector Hard Line Replacement
你所需要的
  1. Mercedes W123 Fuel Injector Hard Line Replacement, Fuel Injector Hard Line: 步骤 1 中的图像 1,1
    • Begin by marking the hard lines. Each one goes in only one location, it will make it easier to re-install the lines or to install your new lines if you mark where each shaped line goes on the injection pump/injectors.
  2. Mercedes W123 Fuel Injector Hard Line Replacement: 步骤 2 中的图像 1,2 Mercedes W123 Fuel Injector Hard Line Replacement: 步骤 2 中的图像 2,2
    • Then begin removing the clamps that hold adjacent hard lines together.
    • You'll use a 8mm socket on top of the bolt that holds the clamps together, and a 8mm box end wrench on the bottom nut that the bolt goes in to.
    • Go slowly with this and be careful to not drop the nuts or clamp pieces as they can fall behind the injection pump. It's not impossible to get them out, but it can be difficult.
    • The second picture shows the hard lines with all of the clamps removed. Be sure to re-install all of the clamps on the lines; they help prevent the lines from vibrating excessively. The vibration is what tends to cause them to crack!
    You do not have to take apart the clamp. Loosen the bolt and nut and slip the whole clamp off. Replace the same way. Again DO NOT completely disassemble the clamp.
    James Scanlan - 回复
  3. Mercedes W123 Fuel Injector Hard Line Replacement: 步骤 3 中的图像 1,2 Mercedes W123 Fuel Injector Hard Line Replacement: 步骤 3 中的图像 2,2
    • Now, use a 17mm wrench loosen the rear-most nuts on the hard lines at the injection pump.
    • Then, use the same wrench to loosen the nut on the same hard line at its respective injector.
  4. Mercedes W123 Fuel Injector Hard Line Replacement: 步骤 4 中的图像 1,1
    • You can then remove that hard line.
    • Proceed in the same manner for the other lines until all are removed.
  5. Mercedes W123 Fuel Injector Hard Line Replacement: 步骤 5 中的图像 1,1
    • While your hard lines are off, cover the hard line fittings on the pump as well as at each injector to prevent contamination from entering. The injector nozzles have very small openings that can be easily clogged.
结论
5等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,040 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
2条评论
Excelente Guia Muchas gracias!!!
Pippenpy - 回复
do you need to bleed the lines after you put them back on?
john umbanhowar - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 35
总计 11,055
