跳转到主内容
Mercedes W123 Fuel Filler Neck Seal Replacement
你所需要的
  1. Mercedes W123 Fuel Filler Neck Seal Replacement, Fuel Filler Neck Seal: 步骤 1 中的图像 1,1
    • When inspecting your fuel filler neck seal look for dryness, brittleness, or like on this particular diesel W123 obvious damage. This was caused by drips of B99 biodiesel on the already aged rubber seal.
  2. Mercedes W123 Fuel Filler Neck Seal Replacement: 步骤 2 中的图像 1,1
    • Gently pry around the edge of the old seal with a flat blade screwdriver or a large plastic spudger type tool. The old seals often stick slightly to the car.
  3. Mercedes W123 Fuel Filler Neck Seal Replacement: 步骤 3 中的图像 1,1
    • Pull the seal off of the fuel filler neck. It will look like this once the seal is off.
  4. Mercedes W123 Fuel Filler Neck Seal Replacement: 步骤 4 中的图像 1,2 Mercedes W123 Fuel Filler Neck Seal Replacement: 步骤 4 中的图像 2,2
    • Use your thumb to press the new seal in around the filler neck. The new seal has a lip on the back that must be pressed in to the hole around the neck. This lip will grip the metal edge of the hole for a tight seal.
  5. Mercedes W123 Fuel Filler Neck Seal Replacement: 步骤 5 中的图像 1,1
    • Here's one last look at the damage done by the biodiesel. The owner of this W123 will be more careful in the future not to drip fuel on the filler neck seal when filling with B99; at that concentration, biodiesel is very caustic to rubber. Lesson learned!
结论
Once finished, consider covering the rubber seal in a light coating of silicone grease to help preserve it.
10等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
38,983 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,506篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 37
总计 8,264
