跳转到主内容
Mercedes W123 Diesel Oil and Filter Change, Under Car
你所需要的
  1. Mercedes W123 Diesel Oil and Filter Change, Under Car, Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 1 中的图像 1,3 Mercedes W123 Diesel Oil and Filter Change, Under Car, Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 1 中的图像 2,3 Mercedes W123 Diesel Oil and Filter Change, Under Car, Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 1 中的图像 3,3
    • To start, remove the oil cap. This will allow the oil to drain out of the engine faster.
  2. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 2 中的图像 1,3 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 2 中的图像 2,3 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 2 中的图像 3,3
    • Now underneath the car loosen the oil drain bolt. It takes a 13mm socket.
    • Be aware that once the bolt comes loose the oil will come out very quickly. Have a drain pan ready underneath the oil drain hole.
  3. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 3 中的图像 1,1
    • Clean up your drain pan bolt. If you are unsure about how old the pan bolt is, it's best to replace it. Consider replacing it every five or six oil changes. It's cheap insurance.
  4. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 4 中的图像 1,1
    • Wearing gloves during an oil change is a very good idea. As mentioned before, it stains everything. As you can see, even after wiping up, these latex gloves are stained. Imagine what it would do to your skin.
  5. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 5 中的图像 1,2 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 5 中的图像 2,2
    • Next, loosen the two nuts that hold the lid on the oil filter housing. They take a 13mm socket just like the drain plug.
  6. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 6 中的图像 1,1
    • Once the nuts are loosened and removed, lift the cover up and out of the filter housing. Remove the filter as well.
    • Be careful as you remove the cover. It can be easy to disconnect some of the vacuum lines that cross over and next to the oil filter housing. If this happens you may cause issues with the vacuum system such as the locks, the shut-off valve, or transmission.
    • Note that when you remove the oil filter, the bit of oil left in the housing will then drain from the drain plug. Make sure to leave the drain pan underneath until you re-install the drain plug towards the end of the guide.
  7. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 7 中的图像 1,1
    • Make sure to keep the oil filter in a suitable container. It will slowly drip dirty oil.
  8. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 8 中的图像 1,3 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 8 中的图像 2,3 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 8 中的图像 3,3
    • The new oil filter kit should come with the filter itself, a choice of new crush washers for the drain plug bolt, and a new large o-ring gasket for the oil filter housing cover.
    • It's generally recommended to use the copper crush washer. Copper is a soft metal that crushes well for a good seal.
  9. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 9 中的图像 1,1
    • It is never a bad time to check parts before installing them. This oil filter was slightly crushed at the bottom during shipping. Another one was used instead.
  10. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 10 中的图像 1,2 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 10 中的图像 2,2
    • Replace the rubber o-ring gasket around the lid of the oil filter housing cover. Never re-use the old one.
    • Use a small needle nose plier or a small flat blade screwdriver to help remove the old gasket.
    • Lightly coat the new gasket with some of the new motor oil to help it seal properly.
  11. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 11 中的图像 1,2 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 11 中的图像 2,2
    • Check the o-rings at the tip of the oil filter housing shaft. There are two of them. If they are hardened, or no longer round, they should be replaced. Proper o-rings can be found in any metric o-ring set.
    • It is good practice to replace these every third or fourth oil change as preventative maintenance.
    • The ones shown here are very flat, and brittle. They had to be broken off as all of their elasticity was gone. They had been neglected for some time, and they were doing little good as a seal.
  12. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 12 中的图像 1,1
    • Install the new filter on the housing lid shaft. Then insert the filter in to the housing and snug the lid down with the two nuts you removed in step 5.
  13. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 13 中的图像 1,1
    • Now install the drain plug, in this case a new one, with a new crush washer.
    • While you may re-use the drain plug several times, never re-use the crush washer. It comes with the oil filter, so there's simply no reason.
  14. Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 14 中的图像 1,2 Mercedes W123 Diesel Oil and Filter Change, Under Car: 步骤 14 中的图像 2,2
    • It's time to put in fresh oil. Use a diesel rated oil.
    • Consult your owner's manual for what viscosity to use based on your climate. Where this car is located, 15w40 works year round but a thinner oil such as 0w40 could be helpful for cold starts in very cold climates.
    • Start by putting in about 5 or 5 and 1/2 quarts. Wait a few minutes to let it run down to the oil sump. Then put the oil cap on and start the engine. Make sure oil pressure shows on the gauge fairly quickly. Then let it run for about 1 minute. This will fill the filter housing back up with oil.
    • Then turn off the car and check the oil level. If it's low, add no more than 1/2 quart at a time until it's full. It will take between 6 and 6 and 1/2 quarts. If you want some guidance on checking oil level see the oil level check guide.
    • Never over-fill a diesel engine with oil. It can lead to catastrophic engine failure due to a runaway engine scenario.
结论
Be sure to check for leaks after you've taken a short test drive.
32等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,040 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,528篇指南
3条评论
Judging by the listed oil capacity, I'm guessing that the vehicle in the guide has an OM616. What starting / final oil capacity would you suggest for an OM617A (oil-cooled turbo)? I've been quoted 7.8qts before.
Dan Gambocorto - 回复
Actually, this is a OM671a. The 7.8 qt capacity is the original fill capacity when the engine is filled at the factory.
When changing the oil, you're going to be between 6 and 7 quarts for re-fill as a certain amount of oil (approx a quart) remains in the oil cooler unless you remove the lower oil cooler hose each time you change the oil, which is not generally recommended.
I prefer not to give a specific fill capacity as the better method is to first slightly underfill, then run the engine and check the level before topping off. This ensures that you do not overfill the engine. Being under-filled is less of an issue by far than overfill. Overfill can cause foaming and even a runaway diesel in extreme cases.
Nicolas Siemsen -
What are the dimension of o-rings in step 11 ???
daada - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 26
过去 30 天: 182
总计 51,349
