你所需要的
The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
10等其他人完成本指南。
2条评论
Very informative, descriptive and point on analysis.
