跳转到主内容
Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement
你所需要的
  1. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement, Tail/Reverse/Rear Turn Signal Bulb: 步骤 1 中的图像 1,1
    • The access panel for all of these lights is on the inside of the trunk. There's one on each side. This guide will cover one side; simply repeat on the other to complete the job.
  2. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 2 中的图像 1,1
    • The panel is secured with two thumb screws. Remove these.
  3. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 3 中的图像 1,1
    • Pull the panel out and away from the back of the car, being careful not to force the bulbs out of the holes.
  4. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 4 中的图像 1,1
    • There are five bulbs in each tail light housing. They are as follows:
    • Brake light
    • Reverse light
    • Tail light
    • Turn signal
    • Side marker
  5. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 5 中的图像 1,1
    • To remove any of the bulbs simply turn them counter clockwise approximately a half turn and then pull them out of their socket.
  6. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 6 中的图像 1,3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 6 中的图像 2,3 Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 6 中的图像 3,3
    • Three of the bulbs are #1156
    • One is a #96
    • One is a small 4W blub
  7. Mercedes W123 Brake/Tail/Reverse/Turn Bulb Replacement: 步骤 7 中的图像 1,1
    • Before installing the new bulb consider cleaning the socket with a soft metal wire brush such as the brass brush shown to help remove any corrosion.
    • Then install the new bulb, reassemble the device, and finally, be sure to test that all of your rear lights are working before going for a drive.
结论
10等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,284 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,525篇指南
2条评论
Very informative, descriptive and point on analysis.
George T Peeke - 回复
Und wie wird dies beim Kombi gemacht?
srossius - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 71
总计 12,505
