跳转到主内容
Mercedes W123 Battery Ground Cable Replacement
你所需要的
  1. Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: 步骤 1 中的图像 1,2 Mercedes W123 Battery Ground Cable Replacement, Disconnect the battery: 步骤 1 中的图像 2,2
    • Start by disconnecting both battery terminals, beginning with the negative (-) side, which travels just a few inches to a bolt attaching the other end to the car's body.
    • Never remove your positive (+) cable first or you risk injury from electric shock.
  2. Mercedes W123 Battery Ground Cable Replacement, Remove the old ground cable: 步骤 2 中的图像 1,1
    • Loosen and remove this 13mm bolt that holds the cable to the metal of the car's chassis.
    • Now remove the old ground cable.
  3. Mercedes W123 Battery Ground Cable Replacement, Install the new cable: 步骤 3 中的图像 1,2 Mercedes W123 Battery Ground Cable Replacement, Install the new cable: 步骤 3 中的图像 2,2
    • You can see here that the new ground cable is substantially thicker. It is a 2 gage cable. The ends are also crimped better, protecting the inner wire from corrosion.
    • This cable is also a bit longer than the old one, giving some more wiggle room.
  4. Mercedes W123 Battery Ground Cable Replacement: 步骤 4 中的图像 1,1
    • Install the new ground cable, using the new captive bolt, and nut, that came with it.
结论
Once you've finished, consider covering the terminal where the cable attaches to the battery in a silicone dielectric grease to prevent corrosion.
12等其他人完成本指南。
Nicolas Siemsen
于12/06/13注册
39,040 声望
创作了79篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,463篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 63
总计 8,869
