跳转到主内容
Mercedes W123 disable security alarm
  1. Mercedes W123  disable security alarm, Remove floormats: 步骤 1 中的图像 1,1
    • Remove passenger (right) floor mat(s). Mine had the sound deadening one plus a protective one over the top of that.
  2. Mercedes W123  disable security alarm, Remove plastic kick plate from right footwell area.: 步骤 2 中的图像 1,2 Mercedes W123  disable security alarm, Remove plastic kick plate from right footwell area.: 步骤 2 中的图像 2,2
    • Remove passenger side (right) plastic kick plate. You must move it up to disengage the metal hooks in the car body from the plastic kick plate clip points (one lower, two upper). Tilt the panel counter-clockwise and remove toward rear of vehicle. Takes a bit of patience to manuever it effectively to tilt backward and free from footwell area.
  3. Mercedes W123  disable security alarm, Disconnect security alarm relay: 步骤 3 中的图像 1,2 Mercedes W123  disable security alarm, Disconnect security alarm relay: 步骤 3 中的图像 2,2
    • Disconnect battery ground strap. You might be able to skip this step if you are confident and careful not to do amatuer arc welding of potentially hot wires in these harness plugs. I got by without doing this step your mileage and skill may vary.
    • Disconnect the two multi plugs from the alarm relay. These are fairly stubborn to disconnect. Requires a bit of pressure to remove.
    • I apologize for the fuzzy photo of the wiring harness but I was not able to get a clear shot. The second shot is a closeup of the relay after it is physically removed. I took that step because I don't want this thing annoying me while trying to drive the vehicle ever again.
    • The relay is attached to the kick panel with typical plastic movable core rivets. You can push the core out with any handy tool (I used a pocket knife blade). Mine had only one but hey this is a 31 year old car!!!
    • If you leave it attached to the kick plate you might want to tape over the harness ends somehow so they can't short against those exposed pins.
    • I understand later models of mercedes vehicles use the same relay but also have an additional relay in the dashboard that disables starting the engine. If you google you can probably find instructions for how to work around that "feature". I will not cover that here because I have no vehicle to provide photo context.
    • Reassemble kick plate being careful to make sure the harness is protected from shorting against anything.
    • Reinstall floor mat(s).
    • Reattach battery ground if you disconnected it for safety.
结论
Enjoy the sound of silence.
2等其他人完成本指南。
tcagle53
于06/18/14注册
8,358 声望
创作了10篇指南
团队
Chromebook Cowboys Chromebook Cowboys 的会员
Community
4 名成员
创作了25篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 4,156
