跳转到主内容
Mercedes W114/W115 Cluster Clock replacement and troubleshooting
你所需要的
  1. Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: 步骤 1 中的图像 1,2 Mercedes W114/W115 Cluster Clock replacement and troubleshooting, Cluster Clock: 步骤 1 中的图像 2,2
    • Locate the area that houses the clock. Unscrew the two barrels and place it aside.
    • Carefully pull out the clock without damaging any other parts.
  2. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 2 中的图像 1,3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 2 中的图像 2,3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 2 中的图像 3,3
    • Connect the screw (located behind the clock) to the negative supply of the battery, and then the small pin to the positive supply.
  3. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 3 中的图像 1,3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 3 中的图像 2,3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 3 中的图像 3,3
    • To check the clock, set the time to something you can remember and set it aside.
  4. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 4 中的图像 1,3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 4 中的图像 2,3 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 4 中的图像 3,3
    • To check the power supply of the clock, locate the electrical connector and find the pin on it which supplies the power (12v) to the clock.
    • Take a small bulb and socket and bridge a wire from the 12v pin supplied from the electrical connector, to one of the two wires on the bulb and socket.
    • Next find a ground supply nearby ( the best place would be the key hole) and bridge another wire from it to the second available wire on the bulb and socket.
    • If the bulb lights up, it means your clock has power.
  5. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 5 中的图像 1,2 Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 5 中的图像 2,2
    • If the bulb lights up, the power supply to the clock is good.
  6. Mercedes W114/W115 Cluster Clock replacement and troubleshooting: 步骤 6 中的图像 1,1
    • Before putting the clock in, clean the holder with a sand paper or a flat headed screw driver.
    • Start reassembling the dashboard by following the guide in reverse order.
    • While reassembling, be careful not to damage the wire harness , oil pressure meter hose, and temperature meter cable.
结论
4等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 18
总计 6,527
