跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Replacing the radio motherboard is a demanding task involving several screws, wires, and some soldering experience. Also, take into account that the radio and audio port motherboards are interconnected and must be replaced together. For more information on soldering reference the iFixit soldering guide.
  1. Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
  2. This step will require at least a 30 mm Phillips #1 screwdriver.
    • This step will require at least a 30 mm Phillips #1 screwdriver.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws.
  3. The bottom panel screws and screw covers must be removed in order to access the back panel.
    • The bottom panel screws and screw covers must be removed in order to access the back panel.
    • Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
    • The adhesive on the screw covers should be sticky enough to put the covers back on when re-assembling the device.
  4. Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 12 mm screws with a long Phillips #1 screwdriver.
  5. To remove the back panel, use the plastic opening tool and gently work around the outline of the panel.  The outline wraps around the sides and can be spotted at the top back of the device. To remove the back panel, use the plastic opening tool and gently work around the outline of the panel.  The outline wraps around the sides and can be spotted at the top back of the device.
    • To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
  6. Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed. After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands. Carefully pull the panel off.
    • Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
    • After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
    • Carefully pull the panel off.
  7. Manta 螺丝刀工具包
    日常维修的112个替换头
    Upgrade Your Toolbox
    Manta 螺丝刀工具包
  8. Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
    • Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
  9. If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom. If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
    • If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
  10. Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Remove the five 6 mm screws at the top with the same screwdriver.
  11. Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
    • Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
  12. Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner. Use moderate force to pry it open and take the cover off.
    • Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
    • Use moderate force to pry it open and take the cover off.
  13. A plastic sheet is in between the radio motherboard (the upper brown board) and the audio port daughterboard (the lower green board) coming from the right speaker housing. Be careful when removing the back panel as to not damage the boards. Remove the bottom panel of the boombox by carefully pulling the  panel straight backwards from the boombox until the boards are free.
    • A plastic sheet is in between the radio motherboard (the upper brown board) and the audio port daughterboard (the lower green board) coming from the right speaker housing. Be careful when removing the back panel as to not damage the boards.
    • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
  14. Pull out the 5 white pinhead connectors using an IC (Integrated Circuit) extractor. Pinch the IC extractor just under the top lip of the wire housing. There are two 10 pin connectors, one 8 pin connector, one 7 pin connector, and one 2 pin connector. When reassembling, there is only one way to reinsert the pinhead connectors. Make sure the orientation matches that of the receiving connector on the motherboard. When reassembling, there is only one way to reinsert the pinhead connectors. Make sure the orientation matches that of the receiving connector on the motherboard.
    • Pull out the 5 white pinhead connectors using an IC (Integrated Circuit) extractor. Pinch the IC extractor just under the top lip of the wire housing. There are two 10 pin connectors, one 8 pin connector, one 7 pin connector, and one 2 pin connector.
    • When reassembling, there is only one way to reinsert the pinhead connectors. Make sure the orientation matches that of the receiving connector on the motherboard.
  15. Use the Phillips #1 screwdriver to remove the three 8 mm screws holding the motherboard in place. Use the Phillips #1 screwdriver to remove the three 8 mm screws holding the motherboard in place.
    • Use the Phillips #1 screwdriver to remove the three 8 mm screws holding the motherboard in place.
  16. Detach the smaller green audio port daughterboard by removing the two 8 mm screws with a Phillips #1 screwdriver. Detach the smaller green audio port daughterboard by removing the two 8 mm screws with a Phillips #1 screwdriver.
    • Detach the smaller green audio port daughterboard by removing the two 8 mm screws with a Phillips #1 screwdriver.
  17. Detach the black ground wire by desoldering it from the inner case. Visit the soldering guide for help with desoldering.
    • Detach the black ground wire by desoldering it from the inner case.
    • Visit the soldering guide for help with desoldering.
结论
2等其他人完成本指南。
Michael Johnson
于2014年01月31日注册
237 信誉积分
创作了2篇指南
团队
Cal Poly, Team 2-9, Amido Winter 2014 Cal Poly, Team 2-9, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G9
5 名成员
创作了6篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 294
