1. Locate the 'OPEN' tab on the battery compartment. Pull the tab upwards and remove the cover using your finger. Remove the batteries.
    • Locate the 'OPEN' tab on the battery compartment.
    • Pull the tab upwards and remove the cover using your finger.
    • Remove the batteries.
  2. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Locate the screws on the bottom of the device that hold the upper and lower halves together. Remove the (5) 19mm screws. Grasp the top and bottom and gently pull apart.
    • Locate the screws on the bottom of the device that hold the upper and lower halves together.
    • Remove the (5) 19mm screws.
    • Grasp the top and bottom and gently pull apart.
  4. Locate the small silver transistor between the front left speaker and the tuning knob.  The antenna should be attached directly below the transistor.
    • Locate the small silver transistor between the front left speaker and the tuning knob. The antenna should be attached directly below the transistor.
    • Deolder the antenna wire from the circuit board, and remove the wire.
结论
Aubrey Frank
于2018年02月15日注册
393 信誉积分
创作了4篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 5
总计 95
