简介
We will be disassembling the laptop down to the heatsink and CPU, to apply some thermal paste with a higher grade of conductivity.
你所需要的
Remove the battery by sliding both sliders to the left.
Hold the left slider as you slide the battery away from you.
Undo the white and black cable, and the screw.
Lift the wifi board up and away from you.
lift the plugs on the black and white cable perpendicular to the board. do not pull hard on the cables.
thomas4946 - 回复
Alternative wording: gently lift off the plug perpendicular to the board, do not pull hard on the cable
thomas4946 - 回复
9等其他人完成本指南。
