跳转到主内容
Maze Speed SSB-508 Speaker and Microphone Replacement
你所需要的
  1. Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: 步骤 1 中的图像 1,3 Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: 步骤 1 中的图像 2,3 Maze Speed SSB-508 Speaker and Microphone Replacement, Speaker and Microphone: 步骤 1 中的图像 3,3
    • With the phone face down, remove the back cover with the plastic opening tool. For easiest access, insert the plastic opening tool in the bottom left corner.
  2. Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 2 中的图像 1,1
    • After the back cover is removed, remove the battery, sim cards, and micro SD card. These components are highlighted in red.
  3. Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 3 中的图像 1,3 Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 3 中的图像 2,3 Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 3 中的图像 3,3
    • Using the screwdriver, remove fourteen 2mm screws to access the internal casing of the phone.
    • After the screws are removed, use the plastic opening tool to remove the internal casing cover.
  4. Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 4 中的图像 1,2 Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate the wire that attaches the motherboard to the daughter-board of the speaker and mic. Using tweezers, disconnect the wire from the motherboard.
  5. Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 5 中的图像 1,3 Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 5 中的图像 2,3 Maze Speed SSB-508 Speaker and Microphone Replacement: 步骤 5 中的图像 3,3
    • Using your soldering tools, un-solder both set of wires that are connected to the daughter-board.
    • You may now replace the old speaker and mic with new accessories.
结论
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 936
