跳转到主内容
Maze Speed SSB-508 Power and Volume Button Replacement
你所需要的
  1. Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: 步骤 1 中的图像 1,3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: 步骤 1 中的图像 2,3 Maze Speed SSB-508 Power and Volume Button Replacement, Power and Volume Buttons: 步骤 1 中的图像 3,3
    • Remove the back cover by gently prying open the bottom left corner of the case with the plastic opening tool.
  2. Maze Speed SSB-508 Power and Volume Button Replacement: 步骤 2 中的图像 1,2 Maze Speed SSB-508 Power and Volume Button Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • There are three areas holding the power and volume buttons in place. Gently pull the bottom of the power button with a pair of fine-tip tweezers to release the lower half.
  3. Maze Speed SSB-508 Power and Volume Button Replacement: 步骤 3 中的图像 1,3 Maze Speed SSB-508 Power and Volume Button Replacement: 步骤 3 中的图像 2,3 Maze Speed SSB-508 Power and Volume Button Replacement: 步骤 3 中的图像 3,3
    • Carefully remove the top section of the button with the fine-tip tweezers . This should free the button completely.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 434
