跳转到主内容
Maze Speed Motherboard Replacement
你所需要的
  1. Maze Speed Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Maze Speed Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Maze Speed Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the back cover by inserting the plastic opening tool at the bottom left corner of the device.
  2. Maze Speed Motherboard Replacement: 步骤 2 中的图像 1,2 Maze Speed Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove fifteen 2mm Phillips #00 screws.
  3. Maze Speed Motherboard Replacement: 步骤 3 中的图像 1,3 Maze Speed Motherboard Replacement: 步骤 3 中的图像 2,3 Maze Speed Motherboard Replacement: 步骤 3 中的图像 3,3
    • Lift the plastic opening tool up at the bottom left corner to create the gap.
    • Repeat this through all corners to remove the internal casing.
  4. Maze Speed Motherboard Replacement: 步骤 4 中的图像 1,3 Maze Speed Motherboard Replacement: 步骤 4 中的图像 2,3 Maze Speed Motherboard Replacement: 步骤 4 中的图像 3,3
    • Unscrew the 2mm screw at the bottom right of the motherboard.
    • Remove the internal antenna casing from the motherboard.
  5. Maze Speed Motherboard Replacement: 步骤 5 中的图像 1,2 Maze Speed Motherboard Replacement: 步骤 5 中的图像 2,2
    • Unplug the speaker at the top of the motherboard.
  6. Maze Speed Motherboard Replacement: 步骤 6 中的图像 1,2 Maze Speed Motherboard Replacement: 步骤 6 中的图像 2,2
    • Desolder the gold ribbon that is connected to the motherboard at the bottom left corner.
  7. Maze Speed Motherboard Replacement: 步骤 7 中的图像 1,3 Maze Speed Motherboard Replacement: 步骤 7 中的图像 2,3 Maze Speed Motherboard Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use tweezers to remove cable from the ZIF connectors located at the bottom left of the motherboard.
    • Use the tweezers to remove the second cable from ZIF connector located to the right of the speaker that you unplugged in step five.
    • ZIF connector stands for Zero Insertion Force. Flip the small locking tap before removing the cable.
  8. Maze Speed Motherboard Replacement: 步骤 8 中的图像 1,2 Maze Speed Motherboard Replacement: 步骤 8 中的图像 2,2
    • At this point, the motherboard should be able to be lifted up from the bottom.
    • Use the tweezers to dislodge the speaker.
    • After the speaker is dislodged, flip the motherboard up so that you can see the cable.
    • Using a soldering tool, desolder the cable from the back of the motherboard.
  9. Maze Speed Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the motherboard from the back.
结论
You have now successfully taken out the old motherboard and replaced it with a working one. To reassemble your device, follow these instructions in reverse order.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 16
总计 446
