跳转到主内容
Maytag MVWX655DW1 Washer Basket Hub Replacement
你所需要的
  1. Maytag MVWX655DW1 Washer Basket Hub Replacement, Washer Basket Hub: 步骤 1 中的图像 1,1
    • Use a 1/4-in Flathead screwdriver to remove the three 5mm screws behind the washing machine.
  2. Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 2 中的图像 1,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 2 中的图像 2,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 2 中的图像 3,3
    • Tape the lid down so it does not open when removing.
    • Pull the lid forward with your thumbs while pushing against the washer with your fingers.
    • Lift the lid up and place on the slots located where you removed the screws from the back.
  3. Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 3 中的图像 1,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 3 中的图像 2,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 3 中的图像 3,3
    • Remove the cap from the agitator with your flat head screwdriver. It should pop right off.
    • Using your 7/16 socket, unscrew the bolt attaching the agitator to the motor shaft.
  4. Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 4 中的图像 1,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 4 中的图像 2,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 4 中的图像 3,3
    • Lift up on the agitator and it should slide off the motor shaft exposing the washer hub underneath.
    • If it is stuck, put bolt back in halfway. Tap the bolt with a hammer while pulling up on the agitator to jog it loose.
  5. Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 5 中的图像 1,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 5 中的图像 2,3 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 5 中的图像 3,3
    • Use your Phillips #3 screwdriver to pull the retaining slip out.
    • Unscrew the six screws with the same Phillips #3 screwdriver to remove the hub.
  6. Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 6 中的图像 1,2 Maytag MVWX655DW1 Washer Basket Hub Replacement: 步骤 6 中的图像 2,2
    • Take the new hub and slide it over the motor shaft.
    • Align the holes by only slightly screwing in each screw and turning the hub until all holes are aligned and screws are in.
    • Tighten all screws and then put new retaining clip into hub.
结论
Kyle
于02/18/21注册
133 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 38
过去 30 天: 194
总计 8,312
