跳转到主内容
Maytag Bravos Drive Belt Replacement
你所需要的
  1. Maytag Bravos Drive Belt Replacement, Drive Belt: 步骤 1 中的图像 1,1
    • Disconnect the power supply from your Maytag Bravos washer. Following this, pull the device approximately 2 feet away from the wall.
  2. Maytag Bravos Drive Belt Replacement: 步骤 2 中的图像 1,2 Maytag Bravos Drive Belt Replacement: 步骤 2 中的图像 2,2
    • This step may be easier with two people.
    • Gently rest the washing machine against a wall or hard surface to keep it slightly elevated. This is important as you will need access to the underside of the machine for the following step.
  3. Maytag Bravos Drive Belt Replacement: 步骤 3 中的图像 1,1
    • Have your 1/4-inch drive ratchet ready for the following step.
  4. Maytag Bravos Drive Belt Replacement: 步骤 4 中的图像 1,2 Maytag Bravos Drive Belt Replacement: 步骤 4 中的图像 2,2
    • Have someone carefully watch over the washing machine and make sure it is firmly rested against the wall to prevent injury.
    • Under the washing machine you will see a plastic cover over the drive belt. To remove this use your 1/4" drive ratchet.
  5. Maytag Bravos Drive Belt Replacement: 步骤 5 中的图像 1,1
    • Following the removal of the cover, place the bolts inside the cover and place to the side somewhere safe.
  6. Maytag Bravos Drive Belt Replacement: 步骤 6 中的图像 1,1
    • Following removal of the cover you will see the drive belt roped around two cogs.
    • The belt is fairly elastic and easy to remove. Remove the drive belt gently and replace with the new belt.
  7. Maytag Bravos Drive Belt Replacement: 步骤 7 中的图像 1,1
    • Reattach the drive belt cover using your 1/4" drive ratchet.
  8. Maytag Bravos Drive Belt Replacement: 步骤 8 中的图像 1,2 Maytag Bravos Drive Belt Replacement: 步骤 8 中的图像 2,2
    • Gently rest the washing machine back against the wall and reconnect all power supply.
结论
To replace your drive belt in your Maytag Bravos washer follow this simple 8 step guide.
3等其他人完成本指南。
Reilly Farr
于02/02/20注册
259 声望
撰写一个指南
团队
2条评论
What’s the trick of getting the new belt on the wheels?
palmer910 - 回复
Where can I find a drive belt for a Maytag Bravos MVWB750WQ0??? I have looked and looked online, and cannot find a source!
J Lipson - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 51
过去 30 天: 215
总计 17,730
