跳转到主内容
Maylong M-295 Motherboard Replacement
你所需要的
  1. Maylong M-295 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use a PH 00 Phillips head screwdriver to remove the screws from the bottom of the tablet.
  2. Maylong M-295 Motherboard Replacement: 步骤 2 中的图像 1,2 Maylong M-295 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Caution: Before completely removing the cover take note of the wires connecting the speaker to the motherboard. Do not pull off the cover too forcefully or else the wires will become unsoldered from the motherboard. (Refer to picture 1)
    • Use a plastic pry tool to gently pry open the tablet by inserting the plier in between the pink back cover and black screen frame.
    • Be sure to go around all corners of the tablet carefully.
    • You may need insert a second pry tool close to the first to keep the cover from closing as you move around the edges.
  3. Maylong M-295 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Slowly flip open the pink back cover and gently remove the speakers from it with a plastic plier.
  4. Maylong M-295 Motherboard Replacement: 步骤 4 中的图像 1,2 Maylong M-295 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use a PH 00 Phillips head screwdriver to remove the seven screws from around the perimeter of the interior screen frame.
    • 3 screws are located on the bottom of the motherboard (as indicated in picture 1)
    • 4 screws are located in brackets around the silver screen plate (as indicated in picture 2).
    • Note: The brackets (small black plastic pieces) will become loose when the screws are taken out and then can easily be removed.
  5. Maylong M-295 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Unsolder wires that are connected to the motherboard by pressing the solder tool to the flux and liquifying it. Then the wire can easily be pulled away from the motherboard.
  6. Maylong M-295 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove motherboard by pulling up and out from the body of the tablet.
结论
Sali Kamara
于09/30/15注册
64 声望
撰写一个指南
团队
Ohio State, Team 2-4, Garvin Fall 2015 Ohio State, Team 2-4, Garvin Fall 2015 的会员
OSU-GARVIN-F15S2G4
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 159
