跳转到主内容
Maylong M-270 Battery Replacement
你所需要的
  1. Maylong M-270 Battery Replacement, Motherboard: 步骤 1 中的图像 1,2 Maylong M-270 Battery Replacement, Motherboard: 步骤 1 中的图像 2,2
    • Use the plastic opening tool to separate the back cover plate from the front.
    • Insert the plastic opening tool in between the back plate cover and the top cover, then slide along edges to pry open.
  2. Maylong M-270 Battery Replacement: 步骤 2 中的图像 1,2 Maylong M-270 Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the two ribbons attached to the device's motherboard.
    • Flip the small black plastic catches down by using the small end of the spudger.
    • Remove the ribbons by gently pulling them away from the motherboard.
  3. Maylong M-270 Battery Replacement: 步骤 3 中的图像 1,2 Maylong M-270 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the two screws from the motherboard.
    • Remove the four screws and metal holds from the edge of the device.
  4. Maylong M-270 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the motherboard by gently pulling it away from the bottom of the device.
  5. Maylong M-270 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Maylong M-270 Battery Replacement, Battery: 步骤 5 中的图像 2,2
  6. Maylong M-270 Battery Replacement: 步骤 6 中的图像 1,3 Maylong M-270 Battery Replacement: 步骤 6 中的图像 2,3 Maylong M-270 Battery Replacement: 步骤 6 中的图像 3,3
    • Remove the battery by using the spudger to gently pry the battery away from metal case around the front screen.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 724
