跳转到主内容
加入维修社区 - 创建账户
Mayflash Arcade Stick F300 Microswitch Replacement
你所需要的
  1. Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: 步骤 1 中的图像 1,3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: 步骤 1 中的图像 2,3 Mayflash Arcade Stick F300 Microswitch Replacement, Metal Backplate: 步骤 1 中的图像 3,3
    • Flip the controller upside down so that the metal panel is facing you.
    • Remove the six 11 mm screws securing the metal panel using a Phillips #2 screwdriver.
    • Once all screws are removed, lift off the panel.
  2. Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: 步骤 2 中的图像 1,2 Mayflash Arcade Stick F300 Microswitch Replacement, Microswitch: 步骤 2 中的图像 2,2
    • Remove the four 9 mm truss head screws fastening the clear plastic square joystick gate to the casing underneath using a Phillips #1 screwdriver.
  3. Mayflash Arcade Stick F300 Microswitch Replacement: 步骤 3 中的图像 1,3 Mayflash Arcade Stick F300 Microswitch Replacement: 步骤 3 中的图像 2,3 Mayflash Arcade Stick F300 Microswitch Replacement: 步骤 3 中的图像 3,3
    • Gently push back on each of the four black locking tabs securing the joystick gate to the casing.
    • Remove the joystick gate.
  4. Mayflash Arcade Stick F300 Microswitch Replacement: 步骤 4 中的图像 1,2 Mayflash Arcade Stick F300 Microswitch Replacement: 步骤 4 中的图像 2,2
    • Lift the chosen microswitch vertically off the rod holding it in position.
    • Desolder the wire from the terminal (metal connection point).
    • Beware of overheating the soldering kit as it can damage electronic components.
    • Use a wire stripper or small blade to strip the insulation approximately 1 cm from the end of the wire before resoldering to the new part.
结论
另外一个人完成了本指南。
Saul Aguiar
于09/05/24注册
293 声望
创作了2篇指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 60
总计 422
