跳转到主内容
MaxWest TAB-7360DC Battery Replacement
你所需要的
  1. MaxWest TAB-7360DC Battery Replacement, Back Hard Case: 步骤 1 中的图像 1,3 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: 步骤 1 中的图像 2,3 MaxWest TAB-7360DC Battery Replacement, Back Hard Case: 步骤 1 中的图像 3,3
    • Insert plastic opening tool at the corner of the screen, in between the back case and the front.
    • Volume buttons will fall out during removal.
    • When opening up the case, have the I/O ports facing you and turn the back case towards the right. There is a short wire connecting the speaker to the logic board.
  2. MaxWest TAB-7360DC Battery Replacement: 步骤 2 中的图像 1,2 MaxWest TAB-7360DC Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully pry the tape from the battery, the bottom left chip, and the ribbon cable towards the bottom-right of the board. The bottom left has a little silver square component that must also be unclipped and untaped.
    • The battery is glued to the back of the screen; therefore pull the battery off of the back with caution. There will be resistance but that's okay.
  3. MaxWest TAB-7360DC Battery Replacement: 步骤 3 中的图像 1,1
    • Gently unclip the data cable retainers and remove the wires from the junctions.
    • Peel the tape off the wire near the bottom of the case.
  4. MaxWest TAB-7360DC Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the two 4mm screws (circled in orange) with a 00 Phillips head driver.
    • Unclip the black plastic retainer near the data port. The PCB should now be able to be gently pulled off.
  5. MaxWest TAB-7360DC Battery Replacement: 步骤 5 中的图像 1,1
    • Make contact with the battery terminals with the hot tip of the soldering iron for a few seconds while slowly pulling the wire away.
    • DO NOT TOUCH BOTH THE BLACK AND RED LEADS AT THE SAME TIME WITH THE SOLDERING IRON
结论
另外一个人完成了本指南。
团队
IUPUI, Team S4-G3, Baechle Spring 2018 IUPUI, Team S4-G3, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S4G3
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 13
总计 1,969
